iOS or android? No iOS?update my app, configure the MQA option, my dac doesn't support MQA, but I can't get it to work.
android, lo siento.iOS o Android? ¿Sin iOS?
I've finally made a test with RME ADI-2 trying to capture real song and comparing it to the original. The song I've chosen was a Diana Krall's Almost Blue, 96 kHZ/24 bit. Test part was 6 sec long.
Was it bit-perfect? No.
It was just close to the original.
DeltaWave said:
Files are NOT a bit-perfect match (match=98,21%) at 16 bits
Files are NOT a bit-perfect match (match=13,87%) at 24 bits
Files match @ 49,9673% when reduced to 20,93 bits
It's 24 bit source. DeltaWave calculates bit-perfectness result for limited 16 bit range as well.Can you share more details? Perhaps maybe more on why do you have 16 bit and 24 bit tests while your source is 24 bit?
DeltaWave calculated that 13.87% of samples in 24 bit range were the same as original ones., and 98,21% in 16 bit range. Which means I have to redo the test to make sure that no dithering has been applied to the recorded data during editing and exporting.Something I don't get: Is 13,87% match indeed close to the original?
May want to try installing Sox. It has a tool called "rec" that makes it super simple to capture data. I set up a shell script to capture 5 secs to .wav file, then process it through to output image, but you can process the .wav with your preferred tool.Something went wrong in Audacity.
Final result is:
Was it bit-perfect? Yes.
6 seconds of exactly bit-perfect data the same as an original.
Apologies for the incorrect previous statement, my fault.
cat record.sh
#!/usr/bin/bash
AUDIODEV=hw:CARD=DAC55780269,DEV=0
export AUDIODEV
rec -V -S -r 44100 -b 24 -c 2 $1 trim 0 5
Capturing itself was fine in ocenaudio. Issue has happened during exporting after editing, because at the moment WiiM is adding a small fade effect in the beginning of the audio stream.May want to try installing Sox. It has a tool called "rec" that makes it super simple to capture data. I set up a shell script to capture 5 secs to .wav file, then process it through to output image, but you can process the .wav with your preferred tool.
Bash:cat record.sh #!/usr/bin/bash AUDIODEV=hw:CARD=DAC55780269,DEV=0 export AUDIODEV rec -V -S -r 44100 -b 24 -c 2 $1 trim 0 5
Also valid for 24 bit?Something went wrong in Audacity.
Final result is:
Bit to bit comparison even on the file level.Also valid for 24 bit?
If you're having a Raspberry PI 4 (?) already, you may want to check out the LMS/Squeezlite way by Picoreplayer (https://docs.picoreplayer.org/getting-started/).I am confused about all this streaming gear. I have a wiiM and a Auris audifi, I also built a raspberry pi a year or so ago. I recently got a new DAC ( smsl do100 ) and I realized that the coax output from the Auris audifi was limited to 44.1 . If I want to be able to get the most of my Qobuz subscription and the new DAC which one should I use? Or maybe I should get the Bluesound node instead. Please advise.
In the US, the Node is currently $100 off..If you're having a Raspberry PI 4 (?) already, you may want to check out the LMS/Squeezlite way by Picoreplayer (https://docs.picoreplayer.org/getting-started/).
Connecting your DAC via USB allows you even more options than using the digital inputs via Coax or Toslink.
It's a lot more DIY/Software config than the WIIM or Bluenode but once done that may be giving
The WIIM is a good device for an excellent price (imho) but not made for everyone's interest. I am happy with it doing Qobuz into my actives.
If you see your happiness in audio files above CD quality you may want to use an USB interface.
