Yep. Maybe a stereo version and a separate DAC chip exclusively for sub out.
What's not? PCM5121 in the Amp not the same DAC as in the Pro?It's not and it's advertised to have ESS chip from 9018 family.
Could you take a more detailed photo of this place? The chip with the hole is the operational amplifier.Here are some photos of the PCB, maybe you can see on the board.
Maybe this will help.Could you take a more detailed photo of this place? The chip with the hole is the operational amplifier.
Тhank you!Возможно, это поможет.
The Amp conceptually is not a "Wiim Pro + ARC + amp + USB" because it was supposed to be based on the Pro Plus. The DAC has changed in the meantime from AKM to ESS and another change would be weird.What's not? PCM5121 in the Amp not the same DAC as in the Pro?
Wiim says the Pro uses it: "... advanced TI PCM5121 DAC produces a remarkable 106 dB SNR ..." here: https://www.wiimhome.com/wiimpro/overview
I'm not arguing the main stereo DAC isn't an ESS Sabre. I'm arguing that it isn't weird that a PCM5121 is being used, again, by Wiim (albeit for the sub-out as you've noted). I still don't understand what is supposed to be weird here.
I dont have any issues. Best product i bought in years.Wiim Amp is on 5th version of the board already... Unless this somehow stabilizes, any measurements are really pointless as what you will be getting will be different from what was measured.
The wiim forum has a very good threads and people have a lot of issues with QC with those units...
I think you need to insert a USB drive, then it will appear in the applicationI just got the amp. It sounds very good. I was able to stream Amazon thru it. I didn't see any option for USB drive on the app. That seemed odd. Would I see it If I was actually using a drive? I will download the manual to see what I am missing.
There is very little in the manual or online w.r.t. using the USB drive. Just notes on power supply (= don't use actual solid state drives since the amp can't provide sufficient current, just thumb drives/sticks) and file format (use NTFS, though FAT32 also worked for me).I just got the amp. It sounds very good. I was able to stream Amazon thru it. I didn't see any option for USB drive on the app. That seemed odd. Would I see it If I was actually using a drive? I will download the manual to see what I am missing.
In the latest version of the app (on IOS anyway) it does not appear under sources anymore - you have to click on "Home Media Share" and click on the WiimAmp in there and there is an option to scan for files.There is very little in the manual or online w.r.t. using the USB drive. Just notes on power supply (= don't use actual solid state drives since the amp can't provide sufficient current, just thumb drives/sticks) and file format (use NTFS, though FAT32 also worked for me).
Load some music on a USB drive (I suggest starting with a modest # of files to initially verify that the indexing of Wiim will meet your needs). Insert into the amp. With some luck (USB currently has intermittent problems on Android, apparently better on iOS) you'll see USB show up under Sources on the app. Click on USB and it will prompt for scanning the drive, click to scan. Now wait . . . it will eventually scan the entire drive. If you repeatedly click on the USB before its done scanning, it will seem (falsely) like you have to initiate another scan to keep it going. Once its fully scanned, the USB will also show up in the app as a server under Home Music Share.
Good luck.
Thank you. I appreciate that a lot.There is very little in the manual or online w.r.t. using the USB drive. Just notes on power supply (= don't use actual solid state drives since the amp can't provide sufficient current, just thumb drives/sticks) and file format (use NTFS, though FAT32 also worked for me).
Good luck.
On iOS or Android?View attachment 346452
My app after update now shows per source volume control option.
