...And there is no (audio) benefit in most situations.
With a balanced headphone connection you can get twice the voltage with a given power supply voltage but unless you're stuck with USB power it's easier to use a higher voltage power supply. Getting enough power/voltage to drive headphones is child's play compared to driving a speaker.
And then you've got an oddball connector.
Regular unbalanced headphone connections ARE standardized as 3.5mm for portable and 1/4-inch for home & pro use. Virtually all other consumer (analog) audio uses RCA or 3.5mm, although the "new" 4-conductor 3.5mm TRRS connector with the additional microphone connection has added confusion.
Virtually all pro equipment uses XLR (with the exception of guitars and headphones).
Agreed with pretty much everything, but want to expand on that last line.
Keyboards and similar electronic instruments are almost never balanced. Low-level (mic) pro gear is always balanced, as might be any gear that is typically located remotely (long lines are safer balanced, reject main hum and other unwanted electrical noise). I say "might be", because keyboards can require a long run in a studio, but that can be handled with a direct box (or a local mixer with XLR out, typical of stage).
To put it more generally, very low level signals are vulnerable, balanced circuitry lets you reject outside noise (which will be common to both legs, and can be rejected). With higher level signals, they aren't so vulnerable without a lot of distance (if it's truly far, you probably want something between to buffer). But even before we worry about exactly how much distance that would be, there is the simple practicality of it. If you're going to be running cables back to a control room, through walls or ceiling or floor, they will be carrying mic signals, keyboards signals, whatever, so they will all be balanced cables whether they need be or not—zero point in have some connections routed different than others. And the cables (or snakes) are going to get routed once and you're not going to even want to dig for where the noise is coming from, so you might as well ru everything balanced that you can. When you're charging $$$/hr for studio time, you can't be debugging your signal path on the fly, they will go elsewhere. Overdoing the signal path is an incredibly small price to pay.
With consumer gear, your turntable is going to be close to your preamp, which is going to be close to your amp. And if you need to futz with an RCA connection here and there, maybe replace the whole cable if it keeps happening, OK. You're mostly likely not going to change the cabling often.
