Which speaker driver shows the best measurements?
sloth_kwj
Seoul, South Korea
I want to make Hall Of Fame(without price/performance) available in market.
Let’s assume tweeters are in nice waveguide. So not considering off-axis FR.
Tweeter :
Midrange :
Woofer 6inch : Purifi ptt6.5 (?)
woofer 8inch :
SubWoofer :
tuga
Oxford, England
Tweeter :
Midrange :
woofer 8inch :
SubWoofer :
Judging from the what's being argued in this thread, any reasonably flat FR driver or which can easily be coaxed with a notch filter used within its optimal operating range will do.
As long as it Spins right you're fine.
You won't even need a 5-way, two is fine.
I don't agree, but then who am I to challenge the mighty guardians of the "Science"?
Biblob
Tweeter :
Midrange :
woofer 8inch :
SubWoofer :
Unfortunately the best drivers aren't simply marked as best in size. That's because it really depends on the design features you're after. Linearity, sensitivity, used bandwidth/XO frequency, closed or BR/PR box, size (internal volume), power tolerance etc. There are more but these I can think of right now.
It's most of time a balance between the above properties. Ofcourse there are some which do more better than others, but as many have said before: it's more about how you use the driver in the complete system, than the individual properties of a driver.
MZKM
Land O’ Lakes, FL
Based off available Hi-Fi Compass measurements and caring about off-axis, distortion, and to an extent sensitivity & on-axis linearity (not needing much work).
”Budget” being <$100/ea
Tweeters
BlieSMa 34A & 34B:
https://hificompass.com/en/speakers/measurements/bliesma/bliesma-t34a-4
https://hificompass.com/en/speakers/measurements/bliesma/bliesma-t34b-4
Accuton C30-6-024:
https://hificompass.com/en/speakers/measurements/accuton/accuton-c30-6-024
Budget kings
Peerless BC25TG15-04 (used in Dennis Murphy’s AAM):
https://hificompass.com/en/speakers/measurements/peerless/peerless-bc25tg15-04
Hi-Vi K1 & Q1R:
https://hificompass.com/en/speakers/measurements/hi-vi-research/hi-vi-k1
https://hificompass.com/en/speakers/measurements/hi-vi-research/hi-vi-q1r
Midranges
SBacoustics SB12CACS25-4:
https://hificompass.com/en/speakers/measurements/sbacoustics/sb-acoustics-sb12cacs25-4
Budget King
Tectonic TEBM46C20N-4B (used in Dennis Murphy’s BMR):
https://hificompass.com/en/speakers/measurements/tectonic/tectonic-tebm46c20n-4b
Dayton RS52AN-8:
https://hificompass.com/en/speakers/measurements/dayton-audio/dayton-audio-rs52an-8
Peerless TC9FD18-08:
https://hificompass.com/en/speakers/measurements/peerless/peerless-tc9fd18-08
Vifa RS125-4 (1000Hz-3000Hz usage, good pairing for AMT/ribbons; low sensitivity, so go D'Appolito):
https://hificompass.com/en/speakers/measurements/vifa/vifa-tc6fc00-04
Midwoofers
Purifi PTT6.5W04-01A:
https://hificompass.com/en/speakers/measurements/purifi/purifi-ptt65w04-01a
Woofers
Not sure
Budget King
SBacoustics SB23NRXS45-8:
https://hificompass.com/en/speakers/measurements/sbacoustics/sb-acoustics-sb23nrxs45-8
sloth_kwj
sloth_kwj
Seoul, South Korea
hardisj
Reviewer
North Alabama
Saddens me to not see any mention of scanspeak products here. Scanspeak makes some of the best speakers available. Their Illuminator line is known for their (Klippel verified) linear excursion with tamed breakup modes outside the typical passband. The 18wu midwoofer has the highest linear excursion of any 7-inch I have seen to date, with about 9mm one-way linear per IEC 62458 .
The Purifi mentioned already is a great option.
hex168
Tweeters
BlieSMa 34A & 34B:
Accuton C30-6-024:
Budget kings
Hi-Vi K1 & Q1R:
Midranges
Budget King
Dayton RS52AN-8:
Midwoofers
Woofers
Not sure
Budget King
The Dayton RS52AN-8 may have to come off the list; measurements of more recent drivers have shown problems:
http://www.htguide.com/forum/showthread.php?33490-Driver-Evaluations-for-a-new-project/page10
(Posts 322-326)
MZKM
Land O’ Lakes, FL
Looking only at those measured by HiFiCompass, they are good (better than equivalent SEAS models if I recall), but I don't remember finding one where I couldn't find better/cheaper offering from another brand.
hardisj
Reviewer
North Alabama
Find a 7-inch midwoofer with (Klippel verified) 9.1mm one-way linear excursion at the (standard) 10% THD/IMD limit (per IEC 62458) like the Scan 18wu.
I'll wait. ;)
(p.s.: the Purifi doesn't even do that)
somebodyelse
When 'cheaper' comes into it you need to be specific about location - some of these have major price differences and/or availability issues depending on where you are.
hardisj
Reviewer
North Alabama
Like I said, looking only at those measured by HiFiCompass.
HFC doesn't offer excursion testing, either.
And, unfortunately, the IEC 62458 method isn't used widely. So many mfg's will state "linear" excursion, but that is based on geometry of voice coil vs gap height and/or +10% delta.
FWIW, every SB Acoustics driver I have tested to date clocks in at about HALF of their spec'd one way "linear" excursion, one-way. Scanspeak is one of the few companies who reliably tests at (or even above) their spec.
I have tested probably close to 100 drive units. I would never shy away from a Scanspeak product based on my experience.
BDE
The right concept is more important than selecting a good or superior speaker driver.
Following some of my usual recommendations:
# Tweeter
Seas-DXT
Beyma TLP150H
BMS compressions drivers
# Mid
Tang Band 75-1558SE
Dayton RS52
# Midwoofer
Wavecor WFxxxBDxx
Scan-Speak Discovery
Seas L16RNX3, L19RNX1, ER18RNX; ER15RLY
SB-Acoustics NBAC
#Woofer/ Sub:
Scan Speak 30W4558T00
Scan Speak 26W4558T00
SB-Acoustics SW26DBAC76 (shallow)
In addition PHL-Audio and B&C-Speaker also have some nice speaker drivers..
MZKM
Land O’ Lakes, FL
Doesn’t THD at different levels tell you a decent amount?
IMD testing has also been done for recent woofers.
AudioXpress uses the Klippel driver analyzer device, but I never know how to read those graphs, other than I guess the more symmetrical the better.
For instance:
https://audioxpress.com/article/test-bench-the-seas-l19rnx1-prestige-titan-series-woofer
No clue if this is good or bad.
andreasmaaan
Which SB woofers have you tested? I saw the Satori MW13P on your website, but none of the regular SB woofers...
