A 15" woofer with 11 mm of linear excursion will move more air. That big Fostex woofer has a very short x-max.
Yeah, if the goal of your audio system is to play back pipe organ recordings faithfully at high SPLs in your home you're probably going to have a hard time on multiple fronts.I have 4 subs in a fairly small space and there are parts when playing the CD pictured below that they still choke on (or maybe the room can't handle it as the drywall starts banging against the studs but in any case it does not sound good or like music). The recording has high output down to 17 Hz or so. Trying to get high SPL below 25 Hz is hard and below 20 Hz you really have to fight for every Hz. Fletcher-Munson is working against you every step of the way. 90 SPL @ 20 Hz does not even sound "loud" although it does shake everything in the room and is kind of fun as long as no one else is home to complain.
Sure, but when mass is used to get the lower frequencies rather than length, as it is in smaller pianos, you get very strong overtones that often overwhelm the fundamental. This is why small pianos, and particularly small uprights, have bass notes that sound "muddy" or even almost like more of a "thud".The frequency a piano string can generate is a function of tension and mass as well as length, so a 27 Hz fundamental can fit in an 8' piano, or even a smaller upright.
Based on my experience using digital pianos, I don't think that's terribly significant. Even if that is captured in the sampling/modeling, it's unlikely the little speaker systems in them are reproducing any tones under 27.5Hz very well. Yet the bass on a good digital piano is much more pleasing than on any smaller upright or baby grand. IMO, of course.Percussive sounds from the hammers and beat frequencies can generate signals well below the fundamentals of the strings.
True, but the low-frequency percussive sounds from hammer strikes are still there.Sure, but when mass is used to get the lower frequencies rather than length, as it is in smaller pianos, you get very strong overtones that often overwhelm the fundamental. This is why small pianos, and particularly small uprights, have bass notes that sound "muddy" or even almost like more of a "thud".
I was not in any way shape or form talking about digital pianos. My wife plays piano and organ, so we have a grand piano in the house, as well as several digital keyboards (and a small'ish digital organ). I'll take the old analog grand, as will she, but playing the digital keyboards through a good sound system they are very good. I did not expect you to take what I said and apply it to a digital keyboard with "little speaker systems". Not sure how you made that leap, but admit I did not rule it out, as I did not even consider it. When I said "piano" I meant a conventional piano with strings and hammers connected to the keyboard.Based on my experience using digital pianos, I don't think that's terribly significant. Even if that is captured in the sampling/modeling, it's unlikely the little speaker systems in them are reproducing any tones under 27.5Hz very well. Yet the bass on a good digital piano is much more pleasing than on any smaller upright or baby grand. IMO, of course.
I think you've misunderstood me. I know you meant a "real" piano with strings and hammers. What I was trying to say is that I don't think those percussive noises from the hammer and beat frequencies that go under the fundamental tone are significant to the tone of a piano, based on the fact that I doubt digital pianos reproduce those well, if at all, yet still sound good (particularly so in the bass register compared to small pianos). I certainly don't intend to say that digitals are "better" than a "real" piano, however.I was not in any way shape or form talking about digital pianos. My wife plays piano and organ, so we have a grand piano in the house, as well as several digital keyboards (and a small'ish digital organ). I'll take the old analog grand, as will she, but playing the digital keyboards through a good sound system they are very good. I did not expect you to take what I said and apply it to a digital keyboard with "little speaker systems". Not sure how you made that leap, but admit I did not rule it out, as I did not even consider it. When I said "piano" I meant a conventional piano with strings and hammers connected to the keyboard.
This is why you buy a high-performance tower speaker folks instead of bookshelf. Same amount of floor space but far better handling of music at elevated levels.
www.audiosciencereview.com
For all the reasons you have stated I have 4 subs with my booskshelf speakers and dual subs with my second system which is a horn and has a 15 inch for the midrange.I do prefer main speakers with fairly deep bass and always have. Crossovers are not brick walls so a fair amount of energy still comes from the mains an octave below the crossover frequency. Higher-order crossovers allow you to reduce the overlap, but I still like having the capability. I have never really understood the idea of running "passive" bi-amping as implemented by an AVR (sending full-range signals to multiple channels and letting the speaker's crossovers separate frequency bands -- wastes amplifier headroom and seems to me of little benefit). Nor do I agree with the "plus" setting putting subs and mains in parallel; again, my idea has always been to isolate the two for the reasons above.
From a practical point of view it is absolutely not worth it. I have 4 subs and two are crossed low (40 Hz). As an experiment I turn off the mains and the other 2 subs to see what is actually playing down low. For most music at normal listening levels they don't do anything audible. At loud listening levels and some content (like EDM or Pipe organs or select pop titles) they do go to work but for the amount of work they are doing the benefit is often quite subtle especially because of the way the brain processes LF and the harmonics. For the amount of expense and added hardware and the potential for aggravating the neighbors the last 10-20 Hz costs / benefits makes no rational sense.I've become a bit curious about how much the juice of the last 10-20Hz in the bass is worth the squeeze recently,
I do not think the percussives influence the "tone" per se, but do contribute to the overall sound that distinguishes a piano from say an organ that has much "softer" attacks" with almost no percussive waves. The beat tones do contribute to sound, but I was writing of those in the context of massed/multiple instruments and singers performing together, not piano (multiple strings are used to "spread" the frequency of each note a bit and those can produce beat tones but I was not thinking of that). When playing with a group, listening for/feeling LF beats are one way we stay in tune (we hope!)I think you've misunderstood me. I know you meant a "real" piano with strings and hammers. What I was trying to say is that I don't think those percussive noises from the hammer and beat frequencies that go under the fundamental tone are significant to the tone of a piano, based on the fact that I doubt digital pianos reproduce those well, if at all, yet still sound good (particularly so in the bass register compared to small pianos). I certainly don't intend to say that digitals are "better" than a "real" piano, however.
If I follow, for acoustic music perhaps not a lot, but it is nice to have and hear when it is there. Electronic music tends to have higher deep bass content, as well as movies (of course). Orchestra pieces that use a lot of percussion, bands with drums, etc. sound better to me with a good set of subs. I am not sure where you stick the "last 10-20 Hz"; if below 20 Hz, it is pretty subtle to me for most music, but is a big part of a lot of action movies. Note my system is for HT as well as music. My system is -3 dB at about 7 Hz in-room but I was not trying for that, it just happened from the way I set up the subs in a modest room.I've become a bit curious about how much the juice of the last 10-20Hz in the bass is worth the squeeze recently,
I was (very) confused about the leap to digital pianos, sorry. Appreciate the kind words.so apologies if my musings on this subject read somehow as an attack on you in any way. You're one of the most valuable contributors around here, so I'd rather shut up than cause you any grief.
That's good to know, actually.Interestingly, years ago I was measuring the signals from some new digital pianos using sampled waveforms, and they did include very low frequency content in their samples.
Sorry, I should have been more specific. The last 10-20Hz I was referring to is the 10-30Hz range. Most particularly the 20-30Hz area, as that seems to be the area that many consider a "must have" for a "true" subwoofer.If I follow, for acoustic music perhaps not a lot, but it is nice to have and hear when it is there. Electronic music tends to have higher deep bass content, as well as movies (of course). Orchestra pieces that use a lot of percussion, bands with drums, etc. sound better to me with a good set of subs. I am not sure where you stick the "last 10-20 Hz"; if below 20 Hz, it is pretty subtle to me for most music, but is a big part of a lot of action movies.
Not something I have studied, sorry (audio was not my day job), though I tend to think the 20 Hz cut off for audio was made for a reason. The deep "wump" from drum strikes and so forth has content to 20 Hz and below, but I have had subs "forever" and have not done any recent study. Be interesting to tweak the LF roll-off from maybe 50 Hz down to 10 Hz and see what happens to the sound. I know 50 Hz is too high a cutoff, at least IME, but when it gets down to 30 Hz and below I don't have any personal data. (When I had speakers limited to ~50 Hz, I missed the deep bass, but designed a servo sub that extended the response to 16 Hz so jumped right to <20 Hz.) Sounds like a project for a Master's student. @j_j might know, or @Floyd Toole though I don't think he is online much these days.Sorry, I should have been more specific. The last 10-20Hz I was referring to is the 10-30Hz range. Most particularly the 20-30Hz area, as that seems to be the area that many consider a "must have" for a "true" subwoofer.
