You should upgrade or use an
alternative browser.
Measurements on this site show plenty of class D amps that are good quality and absolutely transparent. There is no Class D sound or...
If you want to use the PC as a sound processor you don't necessarily need to spend a lot of money as the latency issue is more software...
Yes you can do that. By default, active filters apply to all devices that have the APO installed. If you only install it to the one...
Loading…
Loading…
