Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,292
- Likes
- 5,546
The KH750 is great value, 10 inch, excellent build quality, DSP all for €1,000
So, he sits in a folding chair in the middle of the room?
You can tilt the Ones on top, though. But yeah, that pricing is unfortunate; guess the R&D and software must pay itself.Also, like the Salon2, the Genelec Tower makes the tweeter too high .
Well... ← just follow the links within the link. ^^Floyd Tooles personal Revel HT (how wrong can it be?):
To answer the original question I find it hard pressed to find a better passive neutral speakers than Revel. Here is my two cents on other brands when I auditioned them earlier this yr. Most speakers I listened to were the top of their range and some at prices close to $85k.
Active:
Bang & Olufsen Beolab90: Lack of coherency between Tweeter and midrange. Too much Intermodulation.
Passive:
B&W: Tweeter emphasis. Not a neutral speaker.
Paradigm: Recessed upper midrange. Comes across as bony.
Sonus Faber: Better to look at, than use them to play music.
Wilson: Mid range is muddy. Brass instruments didn't sound natural. Gave me a headache.
KEF: Measures well, but typical co-axial speaker issue - 'lack of air' at higher frequencies.
Martin Logan: Too narrow a sweet spot. Integration with the woofer not coherent.
Focal: Doesnt measure well off-axis.
Magico: Extremely pricey for hardly an improvement in performance.
I am yet to audition Vivid Audio, but those cost 5x than the Revel range!
I completely agree. The W371A was just an example and arguably shows the worst price/performance ratio of any Genelec loudspeaker, thus far. But hey, didn't we just recently talk about Kii THREE's BXT module?
The more realistic approach is to not go for bookshelf loudspeakers - or to add subwoofers like the Rythmik Audio FM8 as "speaker stands"; which is designed for LPF as high as 250(!) Hz. Additional subwoofers [the usual types, <120 Hz] could always be integrated for, let's say, a separate LFE channel.
Genelec s360 is superior to even the most expensive Revel loudspeaker. Revel makes really good passive loudspeakers, one of the best brands. But they dont have top-class quality regarding their crossover-components.Obviously the bigger Genelecs, 8361, S360 or 1237
Or Neumann KH420
Focal actives are not recommended around here but I like their sound, the Trio 6 or Trio 11 will play plenty loud
Some people like to keep in touch with reality, though.post,delete,post,delete,post,delete. If you like revel best then it is best. period, seriously who's reality do you want to live in? I prefer a different brand with my current line of components, but that shouldn't have ANY weight in what you like best.
no other subwoofer or bass module is going to offer the same level of capability.Well more realistic but not as functional. To me the whole point of the W371A is to use the fancy opposing woofers individual DSP to clean up your room issues in the region between 20-500hz. Extension/SPL benefits are secondary to that main purpose. And for that purpose, no other subwoofer or bass module is going to offer the same level of capability.
But yes, you pay for it.
Leaving the price aside, will a Genelec 10" subwoofer due to its ported design perform better than a 10" Neumann sub or 10" Rhythmik sub? As you know I am contemplating between a Genelec Vs non Genelec subwoofer to manage bass for my Genelec actives.Looks like a little better value than the Genelec equivalent, though still not great compared to what you can get from Rythmik at $1,000.
Something unique that you get with the Genelec subs that I appreciate is the spiral port design. It's likely a big reason why they can squeeze so much performance out of a tiny woofer and box with so little power.
Short answer: no. Choose a Genelec SAM subwoofer, if you wish to use GLM - there is really no other advantage.Leaving the price aside, will a Genelec 10" subwoofer due to its ported design perform better than a 10" Neumann sub or 10" Rhythmik sub? [...]
Yes, the point of a correctly implemented ported system is greatly improved distorsion at and above the port tuning frequency due to much reduced excursion. Even for Rythmik, though it's less certain, because I doubt the servo mechanism can overcome the limitations of a sealed design.Leaving the price aside, will a Genelec 10" subwoofer due to its ported design perform better than a 10" Neumann sub or 10" Rhythmik sub? As you know I am contemplating between a Genelec Vs non Genelec subwoofer to manage bass for my Genelec actives.
