Topping D30Pro Review (Balanced DAC)
JohnYang1997
China
Thanks for spending time.
But that only tells me the kHz. It does not tell me when a tone being sent to DAC, both channels of the DAC would output the tone at the exact time or not.
If there's anything other than perfect timing you will see large rise in distortion and/or high frequency roll off. They are not seen here.
Pdxwayne
I see. So, the measurements were not made independent of each other and actually depending on each other? Thanks!
Vini darko
Dorset England
The channels clocks are matched 100% at 0.00001% accuracy at the the test frequency of 1khz. We can also see the sine waves sitting right on top of eachother above indicating 100% phase match. Distortion is matched to 0.00001% too . Only thing is the voltage output shows some imperfection at "only" 0.011Vrms difference.
gvl
SoCal
I am genuinely curious. Which plot in the first post checks for timing between right and left channel?
Constant timing errors between L/R channels would show up on the dashboard, see the Beresford DAC review for example. This is different frim timing errors on DACs paralleled in one channel which is what John referring above.
Pdxwayne
Thanks!
Yeah, my unit has 0.05db difference. It seems Amir's test unit has slightly higher dB difference between channel. I am not worry about that small difference as my X16 is at almost 0.2db!
Phase match should not matter at 1khz, correct?
So, let's say left and right channels are off by 5ms, how would it show up in that chart?
Thanks!
threni
/dev/null
Depends - it it's half a cycle out of phase you won't hear anything at all, which will matter in some scenarios.
NTK
US East
An example: https://www.audiosciencereview.com/forum/index.php?threads/beresford-tc-7520-review-dac.24717/
[Edit] If the timing is off by exactly integer multiples of the period of the sine wave, then the scope view won't show. But the likelihood is tiny.
Pdxwayne
Thanks! Half a cycle at 1khz is like 0.5ms delay, right?
Vini darko
Dorset England
Thanks!
Thanks!
Calculating that is above my pay grade :D
Veri
I am curious why there is 4 DAC chips at all. Why? What is the point?
It is pretty common to parallel DACs to maximise the SNR. Often datasheets even show a chip's mono performance when you use one chip for one channel. It's not per sé worth the extra cost but especially in the case with these "cheaper" cirrus logic chips as used in D30 Pro the performance shows a nice little boost. Especially the single ended out gains a lot compared to single chip performance. Balanced too but more gradual.
anphex
Berlin, Germany
Hi!
Dunno if this is a double post but I was surprised when I went to download a pdf of the user manual for the D30 Pro. I had to double check I didn't confuse the model but it seems that there is an updated version? My DAC has 9 filter modes. Funnily enough the included user manual in the package also only listed those 5 filters that Amir tested.
Pdxwayne
Hi!
Yeah, the manual was not updated. It should be. Mine also got 9 filters.
Lupin
Seems that manual actually was updated for newer batch.
Hmm.. going to check the manual when I get home.
Never bothered even getting the manual out of the box, who read manuals these days..;)
My unit came with FW 1.43 out of the box.
Lupin
Latest release is 2.44 iirc.
Sorry my fault
Made a typo meant to say FW 2.43
Flashed it to 2.44 myself.
Don't notice any difference but hey at least the human nature desire to have the latest and highest number is now satisfied ;)
Jimbob54
Sorry my fault
Always a risky proposition, but at least its not an SMSL device with their propensity to brick on driver/ firmware updates:D
