Topping A50s Headphone Amplifier Review
PuX
I hope one day Chinese brands learn to make their devices look more professional.
Like use one single font for all text, put all inputs/outputs at the same level, stop using small ugly screens, blue (or bright in general) LEDs and so on.
Performance is already nice obviously, looks can be improved much easier.
MadMan
In a vacuum this is nice and all, but it seems to me one would only buy this amp only for aesthetic reasons if you must have a matching stack with the D50s. The 'it's balanced' point doesn't seem relevant when to get any benefit, you need a non-realistic high output single-ended DAC, and if you did have one just save $60 and get an L30. I guess it fills a slot in a perhaps overcrowded product lineup, and maybe for the derpy masses who think 'balanced must be better.'
PuX
wait, it accepts only unbalanced (RCA) but can output to balanced 4.4 mm?
My understanding of what 'balanced' means in 'balanced headphone amp' is lacking, but this makes me even more confused.
Now that I think about it, normal XLR in = 2 * 3 pins, balanced XLR = 4 pins. Extra pins are just ground or something?
And in 4.4 headphone connector there are 5 contacts, while RCA only has 2 * 2 contacts, where does the extra one come from? :)
My best guess right now is 4-pin XLR has separate ground per channel, while 4.4 does not, still confused.
Veri
With 2.0V input, L30 6.3mm outputs 117 mW @ 300 ohm, A50s 4.4mm outputs 209mW @ 300 ohm... so it's still about 2x more powerful even without the "non-realistic" higher-than-2V output DAC. So it's more powerful if you can both use the 4.4mm output but also don't want to shell out for the most expensive Topping A90.
Answer is differential balanced. It is still most definitely balanced... massdrop 789 also outputs balanced 4-pin even with RCA inputs. Nothing too odd, really.
Vini darko
Dorset England
I think part of the problem is the nomenclature. This amp would be better described as full bridge out of the pentacon socket. And single ended out of the 6.4 socket.
ElNino
The target market does seem very specific/narrow. I thought pentaconn-based balanced headphones were still the minority and that most balanced headphones use XLR connectors (but I haven't been following the high-end headphone market, so I could be wrong).
Atanasi
4-pin XLR has two poles for each channel, without a ground connector. 4.4mm also has the ground.
A balanced output usually drives both poles of a channel with inverted signals, while a single-ended output drives only one and grounds the other. Consequently, a balanced output has the voltage doubled. The balanced output works this way even if the input is single-ended.
solderdude
The Neitherlands
You can also have a ground on a 4-pin connector, namely the screen is the 5th (ground) connection. I know Geshelli Erish uses the ground this way.
The reason Topping opted for Pentaconn may well be future proofing but above all size.
Yes, the two are different animals. Balanced input is designed to get rid of currents that flow between chassis of two pieces in the audio chain, causing ground loops. Balanced input eliminates this and can be a great help in reducing chances of hum and noise induced from the upstream PC.
Balanced output should not have been called that. There is no ground reference with headphones so all outputs are "balanced in nature." In this context then its main value is potential for quadrupling output power.
Having the chain inside the device be balanced/differential is of little value and independent of the above.
Berwhale
My Sennheiser HD 660s came with a balanced cable with a 4.4mm pentacon plug which I shall be plugging into an A50s when it arrives.
JohnYang1997
China
Any reason to get this over the L30? Either way, another incredibly showing from Topping
If you need BAL out.
If you need a full stack with P50 power supply.
If you already have D50s.
If you don't like glass front panel on L30 or the knob.
If you like something feels more solid on hand.
Thalis
The RCA Out is passthough if gain is set to 0dB? So its not a pre out? What if gain is at +6? I assume this is "unplug headphones to use RCA Out scenario"?
