Thalis
- Joined
- Sep 2, 2020
- Messages
- 362
- Likes
- 217
It's pre out. Meaning the volume control is still enabled.
Ok got it . After years of using the E10k I actually much prefer a fixed 2V Line Out...
On the balanced, I think I might disagree a bit on that. Balanced is from the impedance perspective. Ideally, the output impedance of hot and cold of the amp, the connector, the cable to the headphone all need to have equal impedance. Headphones are balanced in nature but once you have the 3pin cable it's not balanced anymore. Same goes for the amplifier output the GND is not the same as the output signal in impedance. Especially for traditional unbalanced connector like 6.35mm. Single-ended output amp like SP200, HPA-4 with XLR connector may get away with that in practical sense. Impedance is close enough for each of the 4 signals.Yes, the two are different animals. Balanced input is designed to get rid of currents that flow between chassis of two pieces in the audio chain, causing ground loops. Balanced input eliminates this and can be a great help in reducing chances of hum and noise induced from the upstream PC.
Balanced output should not have been called that. There is no ground reference with headphones so all outputs are "balanced in nature." In this context then its main value is potential for quadrupling output power.
Having the chain inside the device be balanced/differential is of little value and independent of the above.
In pre out mode, will the gain switch make a difference at rca out? ThanksIt's pre out. Meaning the volume control is still enabled.
Yes.In pre out mode, will the gain switch make a difference at rca out? Thanks
There are many reasons for A50s to exist otherwise it wouldn't.
Firstly it's an upgrade to the sort of failed A50.
It didn't live up to the expectations of people (me included at the time as well when I was not a designer here yet). It literally didn't sell a single unit in China the day of release. It's not really that bad comparing to many other products from other companies like IFI, Schiit(at the time), FIIO etc.I would really like to know what's so wrong with A50? Is Topping actually ashamed of that device? Is "fail" a reason why that device has never been tested here, so that it may not swing Topping’s reputation? No, seriously, what's so wrong with A50 considering I haven’t read a bad review about that device on the net yet, and I found them more than a few? Is it somewhat higher output impedance, use with IEMs, switch instead of preamp, neutrality issues, noise, distortion or something else? Interested because I have two of them and really can't compere them with anything except Xonar soundcards and some old integrated amps with pretty bad headphone outputs.
People expect THX performance, at least Atom. It's not even as good as Dx3pro V1.
You can still find the specs and graphs somewhere. It's ok but not impressive.
Only concern from me is the noise with sensitive IEMs. Then it may sound a little bit "excited" due to relatively high noise in the high frequency. If you have one and it works for you then it's great. You don't need to upgrade.Well, no doubt the latest products you made are impressive on paper (I believe in practice as well). But the right question would be is there a justified "sonic" reason to do an upgrade to A50s/L30 from A50 or something similar if using some "ordinary" headphones like Sennheiser HD599/HD600/HD650, AKG K712, HiFiMAN Sundara...? Would the A50s or L30 give a noticeably better sound in any way to these cans? I understand that this is probably an awkward question for you, but... If I could test and compare those devices myself, well...
I will basically use this amp with my Senns hd6xx series but occasionally I may use some iems. Suppose I find the iems like you say a bit "excited", is it ok if I use such adapter https://www.amazon.com/FAAEAL-Conductor-Impedance-Cancelling-Professional/dp/B07FM8GJL4 ?Only concern from me is the noise with sensitive IEMs. Then it may sound a little bit "excited" due to relatively high noise in the high frequency. If you have one and it works for you then it's great. You don't need to upgrade.
Better get an iFi ear buddy / iEmatch thingie which will work a lot more reliably than a cheap $7 impedance filter.is it ok if I use such adapter https://www.amazon.com/FAAEAL-Conductor-Impedance-Cancelling-Professional/dp/B07FM8GJL4 ?
Yes:Is there less crosstalk when using a balanced/differential connection to headphones?
One thing I've noticed with unbalanced headphones regardless of amp is that if I play a signal only in the left channel, turn up the volume fairly loud, and then listen only through the right channel, I hear a faint musical signal in the right earcup. I'm assuming this is due to crosstalk through the common ground. Does it go away with a balanced connection?
