Weird how all pro monitors only need 1 tweeter instead of 15 to produce ~10% of the sound energy in most music.
It is America, isn’t more better?
The Moab struggles with low impedance so let’s add 4 more drivers and that should fix it!
Yeah, but when your listening distance is well over 100 feet (in open air)... most of the issues tend to diminish. Even more so when you're as high as ~85% of the fans (and 100% of the performers) were.I mean... well... there was the Wall of Sound...
That was a whole lot of EV T350 tweeters
Okay, smarty pants! Perhaps you may have beaten the 42 count of 'drivers' but the record was recently broken by the Sphere.I mean... well... there was the Wall of Sound...
Beat that!"The Sphere’s massive audio system was specifically developed for the venue’s unique curved interior. The system consists nearly 1,600 permanently installed and another 300 mobile Holoplot X1 loudspeaker modules, all promising to give engineers precise control of where sound goes in the venue. With each module housing a multitude of drivers, the venue boasts a total of 167,000 individually amplified loudspeaker drivers, backing up the venue’s claim to have installed the world’s largest concert-grade audio system."
Back when I was an audio sales drone circa 1970, we had a pair of those sitting just outside the showroom gathering dust. Nobody was the least bit interested, but just for fun we hooked them up and listened -- definitely not impressive, especially considering their massive size. I have no idea how many drivers that pair had.Good point. The Concert Grands were interesting in that many variants were sold. My recollection is that one could start with a relatively basic version and just keep adding drivers.
source: https://www.worldradiohistory.com/h...o-IDX/IDX/60s/Audio-1967-12-OCR-Page-0041.pdf
This literally can't be real. Is it real? Nah, how can people be THAT stupid?
Yes. Your work is hugely valuable to me as well as many others. Please continue!By that assertion, I am unqualified to analyze the measurements. If so, who is qualified? Just because you disagree with my assessment, it doesn't mean that I should withhold my analysis of them. You can post and say what you want about them and vote. There is a reason we have grown so much. There is a ton of education that goes on through these reviews and methodology I use to present them. Just look at the Stereophile tests which follow your scheme. Hardly anyone understands them and hence the reason measurements had taken the backseat until I started to do them. Graphs need to be self-explanatory so that the issues it discusses can be seen. Some text way later does not remotely do that.
It would save me a ton of time just to spit out the graphs and type some text instead of spending hours in Photoshop to annotate them. I do it because they are hugely valuable.
I thought this was a joke- until I looked at the site. OMGThank you @amirm
As much we may understand Eric’s point of view that a minor cabinet leak can, and will change the port turning, and measuring on a different axis will affect the measurement, I feel that the owner’s reaction was unnecessary.
The approach to critical feedback can be managed in a different way.
After all, this is not the same magnitude of problem like a gross error- like a driver being wired out of phase, or a damaged / non-functioning driver.
I would have thought that a different approach would be more constructive eg. Reflecting on limitations of being able to control a user’s set-up process (eg. not installing feet) or listening on the tweeter axis instead of the woofer axis.
I would think this is a better approach and better for public relations for all involved.
After all, Eric does seem to have other interesting designs worthy of audition / measurement / review.
Ulfberht
Named after medieval-era Viking swords, the Ulfberht loudspeaker is the ultimate hammer/butterfly of sonic expression, striking out at the listener with percussive elements and a constant velocity…tektondesign.com
Regardless of the designer’s appalling behavior, why does this Ulfberht monstrosity merit any consideration?
Not that it matters as Amir is unlikely to deal with its size and Erin is not doing any more Tekton reviews. At over $20K, does not seem very competitive. Stereophile just reviewed a $30K pair of Moabs if you feel a need. For that spend, they are nothing special other than a 10 dB peak at 100 Hz but still somehow manage to get labeled as “neutral” sounding.
I would think one would readily get better value buying active pro speakers with some decent customization capability than these backwards Tektons that look like the designer shat drivers on a baffle!
p.s. am sure that hump between 2-3 kHz gives them added neutrality too!
...or whether he's 'done a Ratner.'Let's see if that saying holds true...
That would be the quoted sensitivity when measuring other people's passive designs. An area calculation that deviates from that specification would really show up those fantasy sensitivity numbers.The reference line is whatever target was defined as the design goal. There is no universal absolute target.
Amir, please read more carefully. First of all, you can do what you want, it's your platform. I was only suggesting that you might move the comments below the graphs rather than directly embedding them, this has nothing to do with whether I agree or not. If you have a feeling that people will be only be looking at the plots anyway and never read comments/captions and therefore the only way to propagate the information/description/judgement/opinion is by embedding it directly, then so be it.By that assertion, I am unqualified to analyze the measurements. If so, who is qualified? Just because you disagree with my assessment, it doesn't mean that I should withhold my analysis of them.
Some great copy in that ad:Back when I was an audio sales drone circa 1970, we had a pair of those sitting just outside the showroom gathering dust. Nobody was the least bit interested, but just for fun we hooked them up and listened -- definitely not impressive, especially considering their massive size. I have no idea how many drivers that pair had.
That's definitely what most do. Lots do not even understand what they are looking at.If you have a feeling that people will be only be looking at the plots anyway and never read comments/captions
