a4eaudio
I do NOT mix music but have been reading about some studio monitors recently and have some questions for those who actually do mix music and have experience with studio monitors.
In particular, I was reading about the Barefoot Footprint01 and Footprint03 monitors. (These are just examples though, I'm not looking for opinions on them as I won't be buying them.) The Footprint01 monitors have an F3 of 36Hz which from what I can tell is quite good for studio monitors. However, one of the comments stated that it was really hard to mix bass well without having separate subs, so he was crossing over to subs and not utilizing that benefit anyways. Max SPL is not stated for these on Sweetwater's product page.
The Footprint03 monitors have an F3 of 45Hz which isn't horrible. Max SPL is 101db (presumably at 1m). I see some Neumann's and Genelec's with max SPL of greater than 110db.
- So, how important is LOW frequency response to you? Especially something like 36hz vs 45Hz and what is the highest F3 you would find acceptable?
- How important is max SPL to you and what is a minimum you would find acceptable?
- Thinking of Hoffman's Iron law, something has to give. Is the size of the monitor much of a constraint (I'm not talking huge, but say 0.50 cubic feet vs 1.0 cubic feet) or are you okay with big if that is what is needed to get the low frequency and SPL requirements?
- Do you prefer studio monitors to have wide directivity, more narrow directivity, or indifferent as long as it is smooth and controlled directivity?
