How do you know the quality of those mixers in order to be able to use words like “absolutely?” May I ask you to share those tests with us?Pretty much in line with the Allen & Heath and Yamaha I suggested above (most likely both those have slightly better preamps) and absolutely no match in terms of preamps to a good interface like the Arturia above or a RME or Motu.
Meanwhile, the RME units you suggested costs 4-5x times the Mackie and supports up to 60 inputs while the OP needs just two. Do you think it is good advise?
