I just discovered this thread.
Seriously ? you put springs under your speakers?
If you wanted to decoupled your speakers from your floor and reduce floor vibrations and its "sound", there was a better way.
I have had this issue, hell most of us in UK have these issues! we mostly have suspended floor boards in UK.
My way of thinking was as follows:
- The speakers need as steady and dead-sounding a cabinet, specially for the front baffle.
- any decoupling under the speakers would cut into the above.
- so how to give the speakers a steady, solid foundation , but be decoupled from my springy floor-boards?
- A heavy slab!
I use a heavy dead slab of granite! 50mm thick, 600mm square slab (remnants bought from a local kitchen manufacturer). The speaker sits on the slab on three stainless steel dome nuts, basically coupled sonically to the slab. The slabs, being natural particle bases, have no resonances.
The slab itself , sits on three raised bolts screwed to the floor-boards. The decoupling is in the form of thick Sorbothane chunks placed between the slabs and the bolts.
- the slabs, can sort of "wobble" on the Sorbothanes. but the speakers and the slabs are coupled together.
Results:
The sheer mass of the slabs creates a high stationary inertia that grips my speakers tight, allowing very little vibration..
the slabs are acting as vibration sinks. Very little vibration is transmitted to the floor-boards and vice versa.
Of course, the floor will shake if I turn up the volume, as sound waves travel through air, but it hardly reaches back to the cabinets.
So I got my cake, and could eat it.
