I doubt whether the ‘Gaias ‘ make the slightest difference and your findings are entirely expectation bias, from sighted comparison, find a way to have both speakers at the same height and compare unsighted.
Was all this done using vinyl for a source.I think I've dialed this in nicely to my taste.
Speaker coupling into the floor and air can definitely effect the sound of vinyl.Vinyl and digital. Why?
How much do they lift them, an inch? Unless sitting very close, this is likely a very small angular change, and should not change the tonality significantly. At a listening distance of 8ft I think it’s roughly only a half degree angular shift.Doubt noted.
Are you saying you don’t even think just the fact the Gaias raised the height of the speaker could have altered the sound?
That’s plausible right?
As for an unsighted test unfortunately I don’t see how I’d pull that off. The Gaias are a pretty involved to take off and on so I can’t see any likely scenario of doing that kind of blind comparison.
I know you have a world class TT that should have very good isolation, but ??
Just wondering, not wanting to start any debate.
Damn, you really love vinyl to run down the hall for every record flip.My turntable is in another room down the hallway.
I guess it keeps you in shape. LOL
You'd hate my place. LOLI like a clean aesthetic for my listening room
That’s the only way they might change the sound, some years ago a company who makes vibration isolation equipment for NFMs and pharma balances ESMs etc ( ie not foo snake oil) measured some speakers here and the amount of vibration transmitted to the floor and it was negligible, if you placed a naked driver on the floor … but that’s one of the reasons why loudspeakers have enclosures.Doubt noted.
No, it is not true. You can find situations where isolation works.That’s the only way they might change the sound, some years ago a company who makes vibration isolation equipment for NFMs and pharma balances ESMs etc ( ie not foo snake oil) measured some speakers here and the amount of vibration transmitted to the floor and it was negligible, if you placed a naked driver on the floor … but that’s one of the reasons why loudspeakers have enclosures.
It is down to the loudspeakers designer to ensure that the enclosure doesn’t store enough enough to produce audible resonance.
www.audiosciencereview.com
It's important for the designer to attempt to control resonance but his abilities are limited,It is down to the loudspeakers designer to ensure that the enclosure doesn’t store enough enough to produce audible resonance.
Yup I am sure if you look hard enough you can find a really poorly designed loudspeaker and a resonant floor, but as has been stated there is still the air borne transmission.No, it is not true. You can find situations where isolation works.
Springs Under My Speakers: What's Happening?
Regarding the audibility I gave an example with a speaker placed on my hifi equipment rack with hard and soft speaker feet (sonic design). First two sweeps are hard coupling, last two with soft coupling. Perhaps an extreme example, but it shows the principle that applies...www.audiosciencereview.com
Yes, indeed you have air borne transmission that may rattle things in the room, as well as direct transmission trough floor and objects. I was just commenting on your "the only way that...".Yup I am sure if you look hard enough you can find a really poorly designed loudspeaker and a resonant floor, but as has been stated there is still the air borne transmission.
There has to be enough vibration transmitted to create audible resonance , and if the floor is that susceptible then it will also be excited by the air borne transmission.
Many ‘isolation’ devices marketed are based on the cup and ball which are direct couplers in the vertical place, magnets are a spring as is an inflated inner tube, if. you really want to isolate your turntable ( which really might benefit) look at rolling air diaphragms.
Agreed. I always felt the spike thing was snake-oil, unless your speakers are dancing around the room.My point being: just use soft feet of any kind. Why use spikes when they do nothing good for the sound, and in worst case, introduce audible distortion?
