Spotify and loudness normalization - how can normalizaed track have higher DR than non-normalized
charleski
Manchester UK
yes, encoding will often create higher peaks, that's why the master should have headroom.
The master needs not to be clipped, and the easiest way to check this is to look at the True Peak, which takes into account inter-sample peaks. A bit of googling shows that Spotify is specifying a max True Peak of -2dB for loud tracks, which is really conservative and, frankly, suggests that their encoder is sub-optimal.
bennetng
This can be trivially done by service providers in automated ways rather than blaming mastering engineers because streaming services providers decide what formats and settings to use, not mastering engineers. Different codecs and different settings create different peaks, in some worst cases the encoded files can have 10dB over as illustrated by iZotope:
https://izotope-rx.livejournal.com/5760.html
If the mastering engineers need to handle this uncertainty they actually need to further cripple the master.
Some engineers may simply set their limiter to limit more severely to "provide" headroom so that their true peak meters don't complain, but result in higher distortion.
Also, if the sources are for examples, from old CDs, then it is simply impossible for the mastering process to predict the future. The service provider need to take care of these things.
bennetng
None of this would be an issue if Spotify would just do floating point output. It’s a much easier ask than getting every single person and label submitting stuff to limit their files to -2 dBTP instead.
Ideally, Spotify should just normalize the masters to ensure the encoded files don't contain 0dBFS+ values by using a two-pass approach, if what they use are not floating-point compliant.
hyperplanar
Los Angeles
That might pose a problem preserving the intended relative loudness of songs when playing albums though, since this normalization would effectively be done per song. That’s also going to take a substantial amount of processing over the back catalog on Spotify’s end. Additionally, Spotify’s actual volume normalization results in 16-bit output and is limited to -1 dBFS, before the volume control. IMO it would be better to have the limiter after the volume control—so with normalization on, the volume control essentially sets a target loudness, while allowing the full digital dynamic range above that to be used as well for more dynamic songs that need it. All of these goals could be most easily facilitated by just having the Ogg decoder output in float.
bennetng
That might pose a problem preserving the intended relative loudness of songs when playing albums though, since this normalization would effectively be done per song. That’s also going to take a substantial amount of processing over the back catalog on Spotify’s end. Additionally, Spotify’s actual volume normalization results in 16-bit output and is limited to -1 dBFS, before the volume control. IMO it would be better to have the limiter after the volume control—so with normalization on, the volume control essentially sets a target loudness, while allowing the full digital dynamic range above that to be used as well. All of these goals could be most easily facilitated by just having the Ogg decoder output in float.
Of course, the most ideal ways are using floating point in every step, and have more flexibility at the client side normalization settings. Did they not earn enough to implement these things? I wonder.
hyperplanar
Los Angeles
Probably a lack of interest if anything. The audio pipeline has probably largely stayed the same from when Spotify was a tiny startup more than 10 years ago. I can’t imagine that many people petitioning Spotify to have their Ogg decoder output float instead of 16-bit integer, so here we are. I thought about posting a suggestion in their community forums, but I have no idea how I would effectively communicate this idea to non-technical people.
Really hope the 16-bit normalization issue is resolved by the time Spotify Hi-Fi comes out, but I wouldn’t bet on it... nothing says Hi-Fi quite like 13-bit resolution in 2021 after all :)
danadam
Also, it’s worth considering how much resolution you lose when setting the normalization to quiet, considering that it’s done in 16-bit. If it turns down the level by 18 dB then Spotify’s output is effectively only 13 bits at best.
If the level is reduced by 18 dB then it means that the album was mastered at -5 LUFS. Such album, at least in my opinion, does not deserve 16 bits in the first place :)
Albums mastered at -23 LUFS (e.g. classical) will retain all 16 of their bits. Albums mastered at -14 LUFS will lose only 1.5 bit.
hyperplanar
Los Angeles
This is true :)
I think it’s the principle and more of a “why not do things the right way” thing for me. How many hours of work would it really take to, at the very least, have the Ogg decoder/normalization output 24-bit integer instead of 16...
HiFidFan
U.S.A
^ I'd love to the results of Amazon HD analysis. I'm trialing it, and a few other streaming services now.
Thomas savage
The Watchman
uk, taunton
lol Amazon mp3 or Amazon HD?
One may clip more than the other (normalisation off in both). But would need to analyse like was done here for Spotty
Well this was while I was in the gym using bose ear buds so..
Iv switch it on now using my hifi , can't say anything terrible has happened , having to be more Liberal with the volume knob lol
Edit , abba definitely sound duller with the normalisation on no matter how much you turn it up .
Different genre's of music will have different loudness levels , i dont see the point personally.
After a bit of EQ adjustment, I'm a fan of this ha ha
It takes away troublesome peaks that can distort and cause annoyance on certain albums . With a bit of eq to liven up the sound , it seems the best of all worlds.
I dont think you can simply turn the loudness normalisation on and leave it there . It definitely robs you of some energy in the upper mid band .
M
Music1969
Lol robs you of some clipping related energy? :p
Hopefully no abba at the gym though? If so, that needs a separate thread LOL
krabapple
Normalization *by itself* does not change DR. It is simply applying gain -- turning the audio up or down to hit a predetermined loudness or peak level.
If DR changes, something else is going on.
krabapple
Right . I just felt that fact got lost in all the discussion and could use emphasizing. The thread is barely about normalization at all, even though the word keeps getting used.
M
Music1969
If you don't want the app to apply limiting (if that is part of the problem) then using normalization probably helps... I think it was an important thing that was discussed. In this case, normalization is highly relevant to this discussion.
Mnyb
Sweden, Västerås
What is the least bad way to use Spotify if your music taste does not include to many crushed masters ?
More jazz and blues ?
Interesting tread thanks @hyperplanar for a very likely hypothesis off how Spotify do stuff.
I’ve often wondered what they are up to as ogg at 320kBps is a decent codec and should behave transparent.
But ive get mixed result usually in most cases its fine and other times I get the feel that it’s not ?
hyperplanar
Los Angeles
I think your safest bet would be normalization set to Quiet in that case. I use Normal because I listen to a lot of electronic stuff that tends to be mastered pretty hot, there's only a few songs in my library dynamic enough to hit the limiter instead of having their gain reduced.
