danadam
- Joined
- Jan 20, 2017
- Messages
- 1,356
- Likes
- 2,150
are the >0 dBFS peaks from playing music with normalization off now recoverable with Spotify’s volume control?
After some investigation (pulseaudio 14.2), AFAICT they are both clamping samples to 1.0.And actually, it might not be the spotify app that is doing the clamping.
First, pulseaudio. The sample format in the sink-input (i.e., the stream that I am sending) is float32le. The sample format in the sink (i.e., DAC) is s32le. Because of that difference a resampler is created and added to the sink-input (see sink-input.c:463). It is a simple "copy" resampler, which means it doesn't change sampling rate but only converts samples from one format to another. You can see this in the logs:
Code:
D: [pulseaudio] sink-input.c: Negotiated format: pcm, format.sample_format = "\"float32le\"" format.rate = "44100" format.channels = "2" format.channel_map = "\"front-left,front-right\""
I: [pulseaudio] sink-input.c: Trying to change sample spec
D: [pulseaudio] sink.c: Suspending sink alsa_output.usb-RME_ADI-2_Pro__57760455__FC0F29710C736C8-00.analog-stereo due to changing format, desired format = float32le rate = 44100
I: [pulseaudio] alsa-sink.c: Sink does not support sample format of float32le, set it to a verified value
I: [pulseaudio] resampler.c: Forcing resampler 'copy', because of fixed, identical sample rates.
D: [pulseaudio] resampler.c: Resampler:
D: [pulseaudio] resampler.c: rate 44100 -> 44100 (method copy)
D: [pulseaudio] resampler.c: format float32le -> s32le (intermediate float32le)
D: [pulseaudio] resampler.c: channels 2 -> 2 (resampling 2)
- mono, with amplitude +9 dBFS
- stereo, with amplitude +3 dBFS
Code:
ffmpeg -hide_banner -f lavfi -i "sine=frequency=220:duration=30,volume=27.06dB" -c pcm_f32le sin.mono.wav
ffmpeg -hide_banner -f lavfi -i "sine=frequency=220:duration=30,volume=24.06dB" -c pcm_f32le -ac 2 sin.stereo.wav
The mono file, when re-mapped by pulseaudio to stereo, will also result in +3 dBFS in each channel. I played them using "paplay" command and I changed the volume using "pavucontrol". Reducing the volume while playing the stereo file did not help. Reducing the volume while playing the mono file stopped the clipping at the expected -3 dB.
I came up with a somewhat hacky idea to trigger this behavior even for stereo files. I added the "remap-sink" module with "right,left" channel map:
Code:
]$ MASTER_SINK="alsa_output.usb-RME_ADI-2_Pro__57760455__FC0F29710C736C8-00.analog-stereo"
]$ pacmd load-module module-remap-sink sink_name=Channels_Switcheroo sink_properties=device.description=Channels_Switcheroo \
master="${MASTER_SINK}" channels=2 remix=no format=float32le \
channel_map=front-right,front-left master_channel_map=front-right,front-left
And now to spotify. I did set "Channels_Switcheroo" for spotify too and reduced the volume but it did not help
