danadam
- Joined
- Jan 20, 2017
- Messages
- 1,470
- Likes
- 2,314
First, by "differences" I only meant my non-perfect null.Vorbis is a pretty decent codecs
Second, the fact that vorbis is clipping does not at all imply that it is not decent. All lossy codecs induce clipping on dynamically compressed material. Here is "Love and Peace or Else" from "How To Dismantle An Atomic Bomb" by U2 (DR4), from top to bottom: original flac, vorbis, aac (fdk), opus (lossy codecs all at 320 kbps):
Maybe.the DR score difference is too big to be explained by lossy compression artifacts.
I stand by my theory that the TT meter is wonky.
Just one thing, earlier you wrote "Because the loudness range is identical". I'd be careful when drawing any conclusions from that. AFAIK loudness range involves quite more complex calculations and won't be swayed by non-linear change (e.g. clipping) in a few samples. DR value on the other hand is a rather simple formula and very sensitive to the max peak value (actually, 2nd max). For example, I can take the above track and reduce its volume by 20 dB and both loudness range and DR value will remain the same. Then I can modify 2 samples and this will not affect loudness range but will change DR from 4 to 10.
Oh, btw, I am talking here about the original DR algorithm, not the new (and proprietary) MAAT DROffline.
