Fosi Audio P4 Preamplifier Review
Rate this preamplifier:
    Votes: 2 0.7%
    Votes: 5 1.9%
    Votes: 69 25.7%
    Votes: 193 71.7%
Glad to see this nice preamp option getting some attention. It really does pack a lot of value in for a very low price. As I mentioned in earlier comments, the only larger issue I had was that using the remote, the volume jumps quickly at the low end of the pot's range. This can be tweaked with the knob as needed, or the knob on the V3 or similar amp if using with one of those. The price is even lower than I was expecting to see when I was using my preview device.
just registered to "attack" me like this... amazing...
no comment..
He just asked you a simple question. I see no attack here. Slow your roll and show some respect and compassion. ;)
I came to incorrect conclusion and I have withdrawn my comment in a follow up post below.
It sured looked like an attack (see Ant's quote above your post) on top of ignorance.
If @OG_Tiredofthe_BS was following ASR he would know that this is a known problem which Amir sometimes refers too.
If an analog pot is not of high quality, is susceptible to imbalance the more we attenuate.
Dunno. If this
You're just being an insufferable know-it-all looking for reasons to complain
Were directed at me, Id probably have interpreted it as an attack.
Dunno. If this
I stand corrected. Missed this and you both are correct to point this out. My apologies to @morillon . The quoted post has been deleted and a Warning was issued. Thank you both for correcting my mistake. No excuses got this one wrong. Appreciate the correction. ;)
Back at the ranch...
I am surprised that 9dB of gain is being so highly rated by ASR members.:oops:
Three levels of gain, switchable. While 3/6/9 is perhaps modest, that's really all this little unit needs. Fosi is developing devices that "meet the middle." If one wants to play at 500 wpc in a huge room, you're probably going to purchase different equipment, aren't you?
This is a review and detailed measurements of the Fosi Audio P4 budget RCA preamp. It was sent to me by the company and as of this writing, is on sale for US $80.
The look is attractive enough for the class. A momentary switch turns on the unit and cycles through inputs, with a reassuring relay click. There are tone controls with detents in the center. Finally and very surprisingly so, the volume control is motorized and activated through remote control (not shown)!!!
Back panel shows exactly what one would need in this class:
Three inputs are provided. A switch nicely bypasses the tone controls if needed. Gain settings are available from 3 to 6 and 9 dB. The only thing missing is trigger support.
Fosi Audio P4 Preamplifier Measurements
The preamp ships with the gain switch set to 6 dB so I ran the dashboard there:
This is excellent performance for the class with distortion at -114 dB or threshold of hearing. So we are noise bound:
We have a wide margin to clear 16 bit audio without impacting its noise floor. Moreover, performance is almost maintained even at highest gain.
We can see the effect of gain on distortion+noise:
IMD test shows exemplary performance when compared to much more expensive reference up to 1 volt output:
Frequency with or without tone control bypass is excellent:
Crosstalk is very good:
As is wideband noise+distortion vs frequency:
The Fosi P4 surprises with incredibly low cost while providing features such as motorized volume control and excellent performance. It simply has no weak point, other than absence of trigger. This is what happens when a company is laser focused on customer needs and excellence in engineering.
I am happy to recommend the Fosi P4 to many of you who need to switch between multiple unbalanced/RCA sources.
Amirm has spoken...Phew! My order is already paid for and awaiting fulfilment at Fosi Audio. Thank you.
This is a fairly generic issue with motorized potentiometers -- at low levels, my 35+ year old Yamaha processor is pretty much useless for small volume increments when its seven-gang pot is turned via its remote.
mine arrived recently and i've been very pleased with it. same comment on the coarse volume adjustments, though, on my system, i reduced the output of the DAC input to give me more granularity when adjusting the volume on on the P4
May I ask when BT is usually used?
I use Bluetooth several times a week from phone and iPad. I teach music and it is fuss free and instantaneous in lessons - YouTube, Apple Music, backing tracks, drum patterns, metronome, tuning notes etc.
I recently received my new P4. I was intrigued by its feature set, which was just what I was looking. However, what I've noticed is this thing is hot(gain). I have the gain set to 3dB and even at only 8:00 this thing is too loud for my near field listening use case. That doesn't allow me any room to fine tune the volume settings. I'd have wished that they would have included a setting for 0dB. My amp does not have the option of lower the gain either. Note; I am using an Ian Canada DAC build with transformer output.
Anyone else experiencing this gain issue?
My DAC link on DIYAudio;
Edit: BTW, the P4 sounds marvelous through my Modulus-86 amp. The Modulus is a little amp is the one to be reckoned with!
Edit 2: My Modulus build images here.
I use bluetooth all the time if I want to stream a podcast or something easily from my phone. Also when friends visit it's nice for them to be able to bluetooth something from their phone to the speakers.
What functions do DSPs usually want?
Mostly room mode corrections and speaker tuning. For example a speaker is close to a wall or corner or there is a room mode that makes some bass sounds too loud and you want to tune that out.
Sounds like a deal. I just wish Preamps included a line level "record output" for connecting to receivers/integrated amps. I have those independently driving outdoor speakers and etc. There are workarounds but I miss those outputs being standard. Old guy here.
Do you mean a line out?
Yes. Those are all common names for a line level out. Not affected by the volume control. They used to be standard and usually labeled record in and out. There are very few preamps that have a fixed line level out anymore. Rogue and Parasound are some of them. i use Older Preamps in my systems..One can use a multi RCA switch and a y cable to get around it. But that is just more connections .
