Sony MDR-7506 Review (Headphone)
Basically these headphones have a hyped center image which strongly masks the sides for whatever reason. The best way to explore this in comparison to other headphones would be through a VST plugin by RJStudios called True Mid/Side which allows to separate or alter the volume of the "phantom center" image independently from the sides while leaving the sides where they are in the image (rather than what a MID/Side encoder would do by squashing the sides together into the same channel). So what I mean is that the phantom center of these headphones to mean is extremely dominant and causes the stereo width to be more narrow than my other headphones. The HD650 and Slanotes Zero I have present a much wider stereo image in comparison.
I also don't think this was his motivation, but a side effect of the width of their stereo image which benefited his mixing style.
It's also fun to try a cross-feed emulator with them, as you were suggesting with how speakers operate, because the result is not a massive difference in comparison to the results with such a plugin for other headphones.
OK, thanks for the explanation. I'll take your word for it (I don't use MDR-7506, little motivation for me to spend time testing what you are saying), that listening to MDR-7506 gives a narrower experience.
That said, I'm not sure that jibes with your complaints about mixing with them. (Again, I'm not advocating mixing with them.) Are you concerned that your mixes will be too wide, because you'd be compensating for the perceived narrow width? If so, OK, that would be you doing you. As for as Scheps, mixing on speakers, which has been the gold standard forever, is a narrower experience than any headphones, so I'm not sure a narrower image is a negative for Scheps. It might be closer to mixing on speakers, for him?
(Note that I've never advocated MDR-7506 for general home listening pleasure, only that there are reasons they are popular for recording. Mainly for monitoring while tracking, but as long as you have them and are used to them, then it's whatever else you want to do.)
@amirm , any forecast on testing my samarium cobalt MDR-7506’s? If it measures the same with high distortion and not great subjective experience, it is what it is. If my vintage made in Japan unit with the samarium cobalt magnets measures differently from the current production which has neodymium magnets, that might explain how the 7506 did well in research but this tested specimen didn’t.
What were my complaints about mixing with them?
I consider the stereo image too narrow because of a hyped center that masks the sides a bit, especially in comparison to the HD650 and Salnotes Zero which have essentially crystal clear sides with a more balanced center within the overall image.
The advantage to that is being able to balance energy in the sides of the mix with more confidence in comparison to references.
In regards to Scheps, he did mention quite a few times that these remind him of his old Tannoy speakers, and also said he didn't use any FR correction on them so I do believe it was both the frequency response and stereo image of these he was drawn to, even though he also basically made it seem that he only was using them because he had a lot of them laying around for drummers to use while he was acting in recording engineer roles when he was operating as a producer out of his studio.
But that's just me reading the tea leaves after trying these for a few years based on inspiration from his interviews.
I think these were a studio standard in the past mostly for monitoring for tracking, but IEMs would be far better suited for the task today, especially for minimizing headphone bleed into mics.
This, your first sentence of your first post I replied to:
I tried mixing with these for a long while, but the stereo width is so narrow that I consider them nearly mono.
You tried, for a long while, but they had shortcomings. That's a complaint, no?
Sure, I'm not complaining that you have an opinion. I was just giving counterpoint, mainly to the idea that Scheps was perhaps not addressing certain details due to shortcomings of the headphones—I thought that might not be the case, due to his history before using headphone. It's just my thoughts, I'm not saying you're wrong and I'm right.
And you know I don't used them, though I did for years, as budget friendly headphones adequately suited for tracking and for scrutinizing tracks. I've used MDR-7520 for years as their replacement—not because they are the best overall sounding headphone I own, but for similar reasons to why 7506 is useful in recording (except a lot better, including a much better sense of warmth when performance a vocal take).
Sure, it seems a little weird that Scheps uses (or can use) 7506 for mixing. But not that weird, people mixing on all sorts of things. And often it's not the case that they get their mixes on large monitors, then only check and adjust on things like Auratones. Sometime they are mixed on tiny speakers, for tiny speakers. I remember a few tunes that I heard on a little boom box, and thought, "wow, huge sound—I bet this will sound awesome on my home speakers!", only to find it sounded tiny and tinny.
In fact, Scheps is certainly a bit that way, he likes his mixes to sound "loud", which is definitely at odds with "balanced". He says he annoys mastering engineers by delivering loud mixes instead of letting them deal with that. I remember Scheps saying that one of the satisfactions he gets is when he's out somewhere and someone is playing one of the songs he mixed on a mobile phone, and it sounds big.
For fun, a couple that come to mind—here's the one I recalled sounding so big when playing it on a small radio while doing some work, then being hugely disappointed at the sound on a good stereo...famous for being maybe the only song to rhyme "parthenogenesis":
Here's a more famous one that sounded so huge on tiny TV speakers, but is pretty hard on the ears otherwise. There's a heartwarming story of the guy who mixed and produced the album, so distraught over how it turned out that he called his mother crying and was going to join her in real estate business or something...then it blew up on MTV and changed his life:
Not sure how headphones can have narrow stereo field. Makes no sense.
Never noticed that with mine.
I've had these headphones for at least three decades and have traveled the world with them. Different pads will improve the sound and EQ is a must to get the best out of these. Are there better headphones? Sure, but for the price and simplicity, and a little nostalgic, these will stay with me. The big drawback for most is the long non-detachable cable.
If SONY simply re-released the V-6 & 7506, exactly as they are, with a detachable cable, and revised pads to further match the best curves (IEF NEUTRAL, 2013 Harman linear without bass shelf, etc), perhaps in a few different colors (starting with white and black?) they would clean up. The M1ST, M-1 have completely different tonality/character, not even remotely close.
I'm listening to music with the MDR-7506 out of an Apogee Duet 3 headphone out. They are a bit bright, but I can tolerate the sound and comfort very well. I l mostly listen to vocal tracks, and right now a mellow sounding track like Julie London's "Julie Is Her Name" is sounding good. There obviously isn't a lot of deep bass, they are small headphones, but overall the sound quality is good because they isolate pretty well and have a decent (albeit, bright) balance. Surprisingly, they are not that fatiguing for me to listen to/wear for a while, and the detail retrieval is top-notch.
In the search for a closed back to wear at work, picked up a pair of these, along with yaxi std pads (per headphone show recommendation).
With eq, found them to be more than fine. 100% would buy again at a total of $140 with pads.
Definitely prefer over the Fiio FT1, as the Fiio s felt and probably looked too bulky. 7506 ear cups are smaller and took some getting used to but now feel fine. Headband and weight are great.
Glad about the choice not to start with the MDR-M1s. No desire to try.
