PenguinMusic
- Joined
- Dec 20, 2019
- Messages
- 635
- Likes
- 379
Hi,
This device is pretty interesting. I would like to ask some questions as those are super important to me.
1°) I would like to use it as a streamer to stream my files over the network. I am used to control my networked players with Android apps and select the device as a renderer. I use Bubble UPnP or Symfonium.
So my question : will the DP5 be detected as a DLNA Renderer out of the box ?
2°) If it can be used as a DLNA renderer, will it play songs as it should ? I have had the Shanling EA5 and it stopped playing songs randomly : sometime after 1 track; sometimes after 2 tracks... Anyone can report if it plays songs nicely for at least an entire album ?
3°) It would be used as a headphone amplifier. Is the power output enough to feed something a little power hungry or will I have anemic sound with demanding headphones ?
4°) Amir reports it is not possible to select input. Do the latest firmwares solve this "stupid" problem ?
Thanks a lot for your answers.
Regards.
EDIT : OK; looked at the specs on a specific website. Output power for headphone amplifier is... 14mW at 300Ohm. Problem solved : insufficient :-(
Regards.
