On the chromoly ride I bent the forks and replaced them with a heavy duty fork and that solved that issue before I broke the handlebars in half wheelying and broke a pedal when stomping on it. I basically busted whatever could not handle me popping wheelies and jumping off of the library stairs and ended up with a decent ride for hybrid use. I think if I buy again I'm going with thick fat 2.25" to 2.5" tires, longer like ~185mm strong crank arms and test ride the frame before committing to something I'm stuck with. Not sure if I need rear suspension for hybrid street use. Knowing me I'll be right back into abusing my ride if I buy another. I test drove a friends new Cannondale with full suspension and I broke the frame jumping off a loading bay dock at work and he got a new frame under warranty so that worked out well. So, I'm hesitant on buying a new ride and what that means. If I buy another I need something tough and rugged because I'm apparently prone to breaking rides and fussy about the ride comfort too.
Doesn't sound like a great bike for your use to start with
How heavy are you? Only guy I know breaking pedals regularly is a huge guy doing huge hucks/drops. I use 2.6 and 2.8 tires on my most recent/most used mountain bikes. Longer cranks have more to do with your leg length, shorter would generally be stronger. I'm not sure what hybrid street use is particularly....I use road bikes and mountain bikes and don't usually use them outside of intended use. Cannondale's nickname is crack'n'fail
Drops to flat are hard on a bike, tho, even if you are somewhat claiming warranty outside of intended use
Better built bikes/components tend to cost more (and more effective generally than say spending more on audio
