Shielded speakers cables
Never in the last 50 years in a variety of homes has speaker wire ever needed "shielding". Seems a product of silly audiophilia cable selling.....I suppose there might be exceptions but....
ps I'm referring to passive speakers which I thought was the basis....
How about San Francisco's Twin Peaks neighborhood right under the Sutro
That was my house 2015 to 2019. No serious headaches.
Speakers sound OK? If you didn't need shield speaker cables, who does?
Except when the purpose of the shielded cables is to prevent the EMI originated from the (class-D) amplifier from radiating to the outside and causes problems for others.
You learn something new every day! I'd not seen that before!
WTMJ puts out 50kW on AM during the day! Now that's what I call RFI :D
Serious RFI, indeed! If you were to walk outside near that on a cold day, you wouldn't need tower a coat or jacket; It would be like being microwaved in a microwave oven. You's simply self heat.
I remember TV built-in speakers requiring shielded magnets in order to not distort the CRT image. Other TV drivers had bucking magnets mounted on the rear of the speaker (those with ceramic donut-shaped magnets) in order to cancel out the speakers' magnetic field enough to stop the picture distortion. Modern day flat screens do not need any magnetic shielding at all. Speakers should be designed to minimize magnetic leakage. Don't waste that MMF (Magnetomotive force); put it in the gap, where it will do some good.
Yep, Jim Brown (again) points out that all cords and cables can act as RF interference antennas.
Yes, but there is no amplification stage after the speaker cables that might be upset by the RFI or might amplify the RFI signal to audible levels. Neither are your speakers going to be very good at reproducing RF interference frequencies so you are very unlikely to hear any benefit from putting a shield on said speaker cables.
Hi, I have a question about shielding speaker cables. Out of curiosity I opened a shielded cable of a well-known brand, to see what the shield was connected to and to my surprise I saw that the shield (aluminium foil) is not connected to anything, neither on the amplifier side nor on the speaker side. I wanted to ask if this configuration makes sense or if it can lead to problems. thank you all.
Whether or not (proper) shielding leads to any measurable let alone audible difference is very dependent upon particulars.
However, any such conditions for a passive loudspeaker in a normal/typical environment and equipment would be pretty rare and rather niche.
Under such a specific situation where a terminated outer aluminum foil shield could conceivably make a different; whether or not a non-terminated shield would have an effect is is well into the academic/theory realm.
In all likely hood, it would be far better to remove or reduce the "aggressor" which is generating the RF energy which is being capacitively coupled onto the speaker cables.
Grounding the shield both ends can be double edged sword. Anyway speakers are passive device so both ends grounding isnt a option . Grounding at at one end makes the shield picky to RF emissions.
It would be an interesting engineering challenge to come up with a situation where it did make a difference. But the aesthetics of a metal/conductive loudspeaker enclosure and metal flooring is a bit too industrial for me.
I've got 20+ foot runs of plain old 12 gauge speaker wire in my home system. I use 12g for everything. Not because I think just because it's "thick" that it's better in some way, but because many moons ago I found three 250 foot spools on clearance for 15 bucks a roll. so now I use it everywhere I need speaker wires. Still haven't used all of even the first roll.
I've never had a noise problem on the speaker runs. Home, auto, etc.....anywhere.
Interconnects? Have had some "noise" that was solved mostly by changing the connection, swapping out/cleaning any tarnish/corrosion and rerouting the lines.
Never speaker wires though. Mine have always "just worked".....
The issue with such reasoning (in general) is that EMI/RFI is very situational. Regardless of how susceptible or immune a system is; an aggressor (source) is also required to have any ill effects. For example, in most conditions a non-shielded untwisted pair RCA may be perfectly fine. However, if laid on a large power transformer one may pickup 60 Hz noise.
I believe I've mentioned this before elsewhere on ASR: When I was a lad, we lived a just few miles as the wave flies ;) from the transmitter and towers a moderate-powered AM radio station* in Baltimore (WFBR). One of my father's loudspeakers (a 'fullrange' Electrovoice Wolverine LS-12 twincone 12 inch driver in a large BR enclosure) would, when the hifi was not switched on, play WFBR quietly but unmistakably. My father's theory was that the speaker wire (18 gauge lamp cord) was acting as a long-wire antenna, and something about the loudspeaker motor (e.g., a 'flaw' in the voicecoil) was acting as a detector. The very sensitive EV driver was responding to the detected signal as best it could.
a pair of LS-12 drivers, unbaffled. :)
Sensitivity of the LS-12, if memory serves, is ca. 96 dB/watt @ 1 meter (calculated from the driver's published EIA sensitivity specification)
_______________
* not a "peanut whistle", but also not 50 kW (as, e.g., was, and still is, WBAL-AM @ 1090 kHz). I think WFBR may have been 5 kW (@ 1300 kHz in those days).
I would wager that it was more likely the 'noise' is being coupled back into the amplifier and finding a route to couple into the signal path prior to amplification.
I had shielded 18 ga speaker wire when I lived near a large radio transmitting tower. It was some kind of Belden with foil and an 18 or 20 drain wire. It worked fine without grounding the drain. Unshielded cable picked up the radio station. Magnetic shielding for the speakers - MuMetal is to keep the magnetic fields of the drivers in, so they don't interfere with the deflection coils of CRT displays, a problem we don't have now. YMMV.
The famous contemporary artist Nam Jun Paik used CRT displays because that was what was available at the time. He illustrates the impact of a permanent magnet on a display. The variable magnetic field of a speaker would have an effect depending on the speaker and the distance.
I once did some consulting for a large car audio company which made subwoofers. Once in a while a fork lift driver moved a pallet load along the wall next to many offices. The computer monitors would all have visual distortions moving from one side to the next as the forklift passed.
IIRC, the graphic artists would go out and yell at them about their color calibrations.
I would think the coupled HF noise would be magnitudes larger than the radiated and re-coupled EMI/RFI.
While the majority of any induced differential noise will dissipate across the low impedance of the loudspeaker, any induced common mode noise will most likely be coupled into the amplifier. Then it's really a question on if it can find a path where it will be amplified.
....However, if laid on a large power transformer one may pickup 60 Hz noise.
sounds like an installation issue to me. I can't think if a single home installation where that is something that can't be avoided rather easily.
That seem like an argument of theory, which is not what I was referring to.
I generally take "theory" as meaning it can't happen except possibly under extremely specific situations. Aka its academic, not a practical consideration.
Additionally, dismissing anything where there can be a difference and then saying there is no differences possible is a tautology.
In any event, its the difference between understanding versus following the "collective wisdom". Without understanding, one is more likely to incorrectly ascribe what made the difference. And that may lead to the wrong "answer" and lead to more snake oil.
Consider this: an individual without any real understanding has purchased an "ultra clean" linear power supply with a very large toroidal transformer in it.
The cable isn't' long enough and he has to string it across the amp. Or, maybe he ran it under the amp for aesthetic reasons.
When he turns it on to listen to the "harmonious beautify" of his new amplifier, he hears audible hum or noise. Not a self-deluded sound mind you. But one which is measurable and would be audible in a properly controlled ABx test.
He asks his "far more knowledgeable" friend for help and he says "Boy, do I have just the right thing for you!".
He shows up with a fancy $1000 brand name Du-jour cable. Upon the cable swap the noise goes away.
What do you think the original guy will think?
Will he have a sudden revelation that it was an "installation issue"?
Or, is it more probable he now things he needs to "invest" in expensive RCA cables?
For some, I honestly think this is how our path towards snake-oil begins. They may experience something real. Only they have no understanding on the why. A change is made which does in fact, "fix it". Not because it was a fancy expensive product, just that the specific particulars were unknowingly changed.
Yawn.
I have no interest in largely pedantic discussions.
Have fun, I’m out.
What happens is: the interference sneaks in thru the amplifier's feedback loop to the sensitive first stage.
The to quote Jim Brown retired Audio Engineering Society interference expert:
Detection at Semiconductor Junctions Every semiconductor junction, whether part of a diode, transistor, or integrated circuit, is quite nonlinear, especially in the voltage region where it is beginning to conduct.
Thanks to this non-linearity, every semiconductor junction functions as a square law detector, detecting any RF signal it sees.
This. It is what I have seen many times in the past. The output impedance of the audio amplifier is very low at audio frequencies, but high at RF frequencies, allowing RF on the speaker wires to be brought inside the amplifier. A good design will include RFI suppression, typically broadband capacitors, but in a poor design the RF signal can sneak through the feedback path to be detected by the input stage and thus converted to audible noise.
The old Delco Kokomo test loop went near an AM transmitter tower resulting in ~V/m field strength whilst attempting to capture a far away station, quite the torture test for the receiver.
The bad news is that I am not sure I have seen shielded speaker cables help; you need to add some sort of RF choke or bypass at the amplifier terminals to shunt the RF signal away from the feedback path. Shielding adds capacitance, but remember there is still a lot of wire and big voice coils inside the speakers that can provide an inlet for RF signal incursion. I have un-fond memories of being able to turn the speakers and hear the interference change...
I haven't seen those two words together in a long long time !
Old fart, what can I say? I worked with the Kokomo team a little many years ago, though never in Kokomo.
Most amps, especially in the days had inductors (often with a resistor bypassing it) and a Boucerot filter (cap + resistor) just for that (stability of the amp).
Understanding the effects of EMI/RFI certainly gets complicated, often the removal/movement of the source (aggressor) is the easiest method.
Taking the simple op-amp, there has been a progression of adding more and more mitigation to the design. Internal "compensation" to help improve stability and reduce damaging oscillation, DC or low-frequency protection diodes for input voltages above the maximum safe inputs, faster acting ESD protection diodes, etc. More and more now have integrated RFI filtering.
That is more for increasing the range of loads the amplifier is stable with, e.g. selectively adding poles to increase phase margin.
One of the issues with filtering conducted EMI/RFI is the typical LCR components have sufficient parasitic which render them far less effective at higher frequencies. Take for example a simple single order low pass filter. We all "know" it attenuates 20dB/decade above its corner frequency. But that is not really true, above a certain frequency they components used for lower frequency filtering and the typical layouts are simply less effective.
This is one reason why component manufacturers will often provide the impedance curves of the components.
Yes, for stability with reactive loads, but that was usually not sufficient RFI protection. Too much leakage around the inductor, and the cap's self-resonant frequency usually too low. But IME, so may not match that of others'. Some had small ceramic caps, or an RC series snubber, for RFI on the speaker terminals. Back in the day, adding a snubber across the (external) speaker jacks was something I did fairly often, mainly in the days of the CB craze when illegal sweep-tube "linears" (RF amplifiers) were everywhere and most of them were horrible for spraying distortion.
Yah... When I was doing tech work and having to deal with RFI constantly, removing the source wasn't usually an option. It was often a nearby CB or Ham station (though I worked with a number of the owners on mitigation -- Hams were usually OK, CB owners a mixed bag) or drive-by "good buddy" with a CB, and shutting down the local AM radio station wasn't an option. Now and then the radio station was out of spec, and they'd fix it, but usually it was just poor RFI rejection by the audio components that was the culprit.
Fridge and HVAC motors were usually easily bypassed (assuming you could get to them). Later light dimmers became popular and an instant RFI source; caps across them usually worked. Ditto fluorescent lights, though the new (decades old now) fast-start versions with small ballasts run around 60 kHz (in the USA anyway) and that gets into everything. LED lights are the latest noise sources. Always something.
