- Joined
- Oct 3, 2019
- Messages
- 330
- Likes
- 548
Is this a new version of that ‘legs or hotdogs’ meme from a while back?
Knees or butt?
It's for me to know and you to figure out he he.Is this a new version of that ‘legs or hotdogs’ meme from a while back?
Knees or butt?
So it can be summed up with this picture, what is mentioned above? Semi-balanced RCA cable, that is:
Edit:
Do you have experience with semi-balanced RCA cables? Please share your experiences about it. Semi vs unbalanced RCA cables, what do you think?
I just put that video in for the sake of the picture. I am not interested in "High End" expensive cable. Sensible "standard" cables that work together with RCA connectors that clamp just enough and I'm good to go.I make all my interconnects this way and they work fine. If you have a long cable run - use balanced, assuming your gear supports this. Use a basic "sound" cable and all is well. Money wasted on fancy "audiophile" cables is much better spent on music for listening pleasure.
Interesting that you do that.I make all my interconnects this way and they work fine. If you have a long cable run - use balanced, assuming your gear supports this. Use a basic "sound" cable and all is well. Money wasted on fancy "audiophile" cables is much better spent on music for listening pleasure.
Theoretically, might make a difference with RF shielding. In reality, probably nothing anyone would hear in a blind test. The cable itself is easier to work with than RG6 coax for example. From a practical standpoint, if you needed to convert to balanced and did not have enough raw cable leftover, you could remove the RCA plugs and replace with XLR.Interesting that you do that.![]()
How did you come to choose semi-balanced RCA vs unbalanced ditto? Did you experience problems with unbalanced RCA cables?
No difference if there is no ground loop current that can flow through the shields. There is a difference if ground loop current is possible, and a cable with both ends' grounds connected is used. A way to get around that would be to single point ground the pieces of equipment with external ground wires, and then going with interconnects that have the ground connection only on one end.So it can be summed up with this picture, what is mentioned above? Semi-balanced RCA cable, that is:
Edit:
I highly doubt there'll be any problems. I used to have the average hobby enthusiast homestudio, with 30 or more devices connected criss cross, patchbay, mixer, submixer, DJ mixer as final preamp, amp, subwoofer, all balanced and unbalanced mixed (some on the same connection), 50 dozen power supplies running from half a dozen power strips, and as the cherry on top, wild cable salad with line and USB and power cables living happily right next to each other. All cheap stuff too.Thanks for the clarification.
I guess I'm asking for trouble. In the near future from my DAC, via unbalanced RCA, into my two subwoofers, then RCA out from the subwoofers, with the HP filter set to either 50,80 or 100 Hz..
..to an active crossover (LD Systems X 223) ..
...and from it unbalanced out (possibly balanced to the amp that will power the bass driver) to two amplifiers that power up the bass and tweeter in my speakers. It kind of smells like a problem here even before I got started and plugged it in.Although I don't know, maybe I'm just painting the devil on the wall so to speak.
In any case, repainting the living room and new skirting boards are to be installed there, so for now my subwoofers are in storage.
Maybe for ballanced lines. But how's that work when you need to connect source ground to destination ground in an unbalanced system. So that shield is still connected to destination ground thru the other grnd to grnd conductor. Are there 2 shields, than why would capacitance be different? Is the ground connection just a wire (so the cable is twisted pair with a shield)? Then its not a coax with all the benefits of coax.Single-ended cables such as those with RCA connectors in which only one end of the shield is attached to ground and the other end is floated can be seen as "directional." The point of such an arrangement is to sacrifice some of the benefit of shielding in order to reduce capacitance.
Yea its fiber optic with converters. One end puts out light the other receives it. What has this to do with th OPs cable?Even though I assume all of you know very well, high-speed high-resolution "optical" HDMI cables do have "one direction"!
I actually use one of these, 10-m long AOC 8K/60Hz 4K/120Hz optical HDMI cable, connecting into Panasonic 55-inch 4K OLED TV (as second PC monitor) from my audio-visual Windows PC; very nice for 4K/120Hz or 4K/60Hz signal transfer into the 4K OLED TV with slim and light optical HDMI cable even 10-m away from my PC (ref. Fig.21 in post #931 on my project thread).![]()
But the source ground is still connected to the destination ground so the noise still gets there.The shield is then connected at the "source" end of the cable only and the "arrows" point to the destination end. Idea being that any noise coupled to the shield drains back to the source "ground".
There is no such thing. Balancing of any sort needs differential receiver at the destination. Anything with RCA in is not differential.Do you have experience with semi-balanced RCA cables? Please share your experiences about it. Semi vs unbalanced RCA cables, what do you think?
Using your third pin ground on the power plugs for signal ground and just connecting the centre pins of the RCA. Ever try that? Why don't you try. Turn down your Amp down so the noise/ hum dosnt blow your speakers.No difference if there is no ground loop current that can flow through the shields. There is a difference if ground loop current is possible, and a cable with both ends' grounds connected is used. A way to get around that would be to single point ground the pieces of equipment with external ground wires, and then going with interconnects that have the ground connection only on one end.
Think about this - connecting the shield at one end only is possible only if you have 2 wires inside the shield. One wire is for the center pin on the RCA plugs and the other wire is for the outer connection on the RCA's. There is no "ground" loop breaking going on in this instance.
Both of these drivers look fairly well-behaved and actually are of almost the same sensitivity. All hell breaks loose in the woofer above 5.5 kHz though, so you will definitely need at least one rather broad notch for that one. (Low Q is good for you, it means you need a relatively low inductance only, so small series resistance.) The area around 10 kHz is particularly critical.I will set the crossover point to the fixed position 2.5 kHz (or if it was 2.6 kHz I don't remember right now). It, 2.5-2.6 kHz, goes well with the bass (SB15NBAC30-4) tweeter (SB26ADC-C000-4). Then I place the bass and tweeter at a suitable c-c distance.
I would suggest not buying them.but if there are arrows on the outer jacket, I'd simply suggest keeping the 'writing' in the same direction![]()
Not if both your pieces of gear are earthed. You are actually breaking a loop. But with most modern gear being two-core double insulated, less of an issue.
The entire "twin-core shielded- break the shield at one end and use the inner pair for RCA" is just a bodge.
But you still get ground loops from the twisted pair ground. And the shield is still conected to both grounds thru the twisted pair. And the best cable for unbalanced is still coax, which that is not.You guys are really making wonder today. Shielded twisted pair cable - 3 wires total. The twisted pair accomplishes the unbalanced connection. The outer shield is only connected at one end - usually the source side. It has nothing to do with signal transmission only shielding. Please note I never referred to this cable as balanced as it is not. Ground loops are not related to connecting a shield this way.
