- Joined
- Oct 25, 2019
- Messages
- 11,148
- Likes
- 14,828
Well, now that I think of it, Bluetooth is actually a digital output...
*makes serious audiophool face*
20 custom presets, and another 22 ready made presets (rock, R&B, classic,...) that to my understanding you can change as well.
It's a mere Psicoacustic effect@amirm Hello!
Have you tried measuring and listening to the hd650 without the internal foam pads?
Almost everyone I know has removed this and are happy, it would be interesting to check the measurements.
Thanks!
Well, it will change the sound. But given its a tweak, most that do it are likely due to think any change is an improvement. Very hard to a/B the change without 2 identical copies, one modded, one not.It's a mere Psicoacustic effect
@amirm Hello!
Thanks!
I made a blind test with 2 pairs. No changes. I didn't imagine the power of a conditioned mind. I can easily detect the difference between mp3 and wav, but in this case... nope.Well, it will change the sound. But given its a tweak, most that do it are likely due to think any change is an improvement. Very hard to a/B the change without 2 identical copies, one modded, one not.
Depending on manufacturer quality control and the magnitude of effects, changes can even be attributed to unit variances doing thatWell, it will change the sound. But given its a tweak, most that do it are likely due to think any change is an improvement. Very hard to a/B the change without 2 identical copies, one modded, one not.
Yup. Hence I said they would need to be 2 identical copies. Which is practically impossible unless you're the manuf and or someone with measurement rig and access to lots of copies.Depending on manufacturer quality control and the magnitude of effects, changes can even be attributed to unit variances doing that
It seemed to me that the famous veil was diminishing, but it could be my mind ... Now I enjoy Eq.
Probably you already have done this, but do you think if a 2014 driver (only the "lollipop") being placed on a more recent chassis it would sound closer to the current revision?The veil is no myth but is not lifted by the foam other than in the mind/eyes of the modder.
Black driver with fresh pads, HD650 from 2017, veiled HD650 (2014)
Try taking the foam out of one earcup only. You will almost certainly hear a difference between the channels.It seemed to me that the famous veil was diminishing, but it could be my mind ... Now I enjoy Eq.
Now that never occurred to me I shall do that, as it maybe only change the upper highs with tiny fraction dB more.Try taking the foam out of one earcup only. You will almost certainly hear a difference.
