Review and Measurements of SMSL SP200 THX HP Amp
AnalogDE
California
Got my SP200 a day early:
FireLion
I'm surprised they didn't make it the same form factor as the SU-8 and then release a black SU-8. Perhaps they have a balanced DAC in the works?
olinko
How does it handle tough to drive headphones if you have any? If I buy this instead of the Monoprice, I might throw some more money to buy the Argons, which I hear need all the wattage you can give them.
AnalogDE
California
I've been using my HE4xx and the power seems good.
FourT6and2
I'm tempted to grab this thing from Apos. They're local and have 30-day return. I can compare directly with 789, HPA4, and HDV820; running with Benchmark DAC3-B. Wish the Monoprice 887 were available. I'd be able to compare all the THX options on the market at once.
Veri
All THX options are fully transparent thoug ;) heh. So they won't sound any different. They'll only differ in usability and maximum power output.
FourT6and2
We shall see. Or, rather... I shall see. While I appreciate info and opinion from other people, there's really only one way to know for sure.
Fesster40
Hi everyone! Please tell me, I want to buy the amplifier under AKGK712pro and Fostex TR50mk3. Also i have RE-400, but it's more for portative player. Choose between ATOM and now here is SMSL SP200....which option would be better in your opinion?
Veri
What's your budget? The SP200 does have higher gain than the Atom which can come in handy for the T50RP.
Veri
[QUOTE = "Veri, сообщение: 257615, участник: 909"] Какой у вас бюджет? SP200 имеет более высокий коэффициент усиления, чем Atom, что может пригодиться для T50RP. [/ QUOTE]
no more than 400$
Then yeah, I'd recommend the SP200 ;)
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Sound great. Will you be sure to properly control the listening sessions so the comparisons could be meaningful? How do you normally do your comparisons?
