elberoth
Just got the new Purified Nords. I did not get a chance to listen (and with my current work load it may take a while ...) but I did manage to open them up and take some pictures.
What is most interesting, is that the Purifi modules show some 20 deg celsius lower working temps than the Ncore ones. They still run hot at idle, but not just as hot.
Here are two amps side to side:
Purifi top
NCore NC 500 bottom
This pic doesn't is not accurate enough, but the NCore modules get as hot as 68'C (154 degrees Fahrenheit). By far the hottest component is the coil:
Purifi on the other hand maxes out at 50'C (all temps at idle with the tops open), with the hottest components beeing that vertical daughterboard an a chip next to it.
PSU transformer, Sparkos discrete voltage regulators on the input board also reach 50'C.
Purified Nord inside:
Purifi board (here you can see the vertical doughterboard that gets so hot and the long chip next to it; the coil on the other hand is warm, but not hot to the touch):
Purifi top
NCore NC 500 bottom
