Review and Measurements of New JDS Labs Atom Headphone Amp
magicscreen
Why are you using the Khadas Tone Board for the Atom (the transparent amplifier)?
Is the IMD hump not a big audible problem?
hyperknot
Yes, it's a lovely combo! My post
solderdude
The Neitherlands
Yes, people can have preferences for poorer sound reproduction fidelity while measurement equipment does not have a preference.
Funny part is that when there are no differences, say the unsuspecting listener is just told there are differences people can still here differences even when the measurements would show (because there were no real differences) the measurements did not change.
People are funny this way.
Raikon_N
Hi guys , just got my Atom today(Yes, finally!) and I am currently trying this setup:
Music from PC -> D30 -> MX3 -> Atom(from headphone out of MX3)
That way, headphone is fixed with the Atom. And I can switch to my passive speaker through MX3.
My question is, speaking with listening to my HE4XX headphone, am I loosing a good amount of sound quality compare with just PC -> D30 -> Atom.
My hearing is not that excellent to probably discern the difference but I'd just like to know.
TIA.
PS: I know, the stack is not good-looking.
DLS79
United States
That's probably confirmation bias, i mean come on new/different must be better. ;)
L5730
East of England
Just a couple of quick questions.
So assuming I use a passive unbalanced RCA switch to bypass the Atom to go to some powered speakers, would I need to switch the ground/shield connectors in a switcher too, or just switch the signal connections?
The Atom uses an AC/AC PSU, I see a barrel connector so I guess there is not a mains ground connection for a ground loop?
I ask this because a ground loop issues was solved with the connection to powered speakers by using their balanced input connections and modifying the audio cable from the unbalanced DAC.
RCA signal > XLR pin 2 (+ve) // RCA ground > XLR pin 3 (-ve) // RCA ground > cable shield // XLR pin 1 (ground) not connected.
EDIT: Corrected the above diagram and colourised the text.
Seeing how the Atom needs to be turned on in order for audio to go to it's RCA outputs, I'd rather simply bypass it altogether.
Ultimately I'd rather have a DAC/Amp combo device so that I can leave EQ APO setup with it for usual Windows OS based sound (Spotify, Youtube etc.) and a separate DAC connected to powered speakers. Two devices, two different chains. But a passive switcher and a couple of batch script shortcuts will do the job.
trl
King of Mods
Iasi, RO
I think that shorting pin1 of XLR to GND would be better, to short-circuit the input inverted amplifier from the speaker. At this moment pin1 is in free air and might get some interferences from the air (very slight chance anyway).
Gradius
Iquique, Chile
You need to short pin 1 and 3 indeed. I have a Mogami, and those are in short circuit.
Posible configurations:
L5730
East of England
I do not wish to derail this thread, but I must respond.
@trl @Gradius
Thank you for your inputs, but I have a ground loop and therefor the ground of the XLR connection at the speaker (amplifier) input cannot be connected to the ground at the RCA output of the DAC.
I hear no hums or buzzes and have 4m of cable sitting in top of a PC case and a 240v AC power strip/extension. I've turned the active speakers up to max. volume and only hear a slight increase in hiss, which I would no matter how they are connected. In my situation this works just fine.
Read the thread for whole discussion if you are bored and have spare time.
https://www.audiosciencereview.com/...owered-audio-devices-discuss.5899/post-135551
At the very bottom:
If the sending end is the unbalanced two-conductor connector; both the shield and the “-” conductor of the pair are connected to the “shield” conductor of this connector. The “+” conductor of the pair is connected to the signal conductor of this connector. The shield is connected to nothing in the T.R.S. connector (receiving end) and the pair is connected to tip and ring similar to a balanced connection.
http://www.lavryengineering.com/wiki/index.php/Adapter_cable
Going back to my OP, with a setup like mine and using a passive switcher box to switch one unbalanced stereo input between two unbalanced stereo outputs, would I need to switch the ground and signal connections or just the signal connections (as is typical in off the shelf switchers)?
Does the Atom have a mains ground and thus the possibility of causing a ground lop with mains ground attached items? I don't think so, but I may be wrong.
Budgeter
The below is my calculation for power output of Atom amp, can anyone check it for me? It can output 250mW @300 ohms load (high gain), which means it will provide 300mW @250 ohms. How will these number change if I use low gain instead? I'm gonna get DT 880 Edition-250 ohms, which is rated @0.1 W, so I don't want to override them.
High gain is 4.5 x => With 2VRms input, we will have 9Vrms output => max 324mW @250 ohm (V^2/R). Assuming there is loss in reality, this theoretical result is around the number that Amirm measured so I guess it is correct. However, when switch this to 33 ohms load, it becomes 2.45W at max volume knob.
The latter result is doubled of what Amirm measured, does that means there is some kind of limitation in electronic part that only allow it produce 1.1W output at 33 ohms? Or should I say 1.1W is only the limit of free distortion range, not the power itself?
Now, Low gain is 1.0x => With 2VRms input, we will have 2VRms output => max 16mW @250 ohm. Is this number too small? However, I guess it is already enough to provide really loud volume, right?
trl
King of Mods
Iasi, RO
250mW @300 Ohms would be 8.66V RMS. given that Atom is unit-gain in low-gain, I would say that max. output level would be 2V RMS, so the desired 8.66V RMS to achieve 250mW @300Ohms would not be possible. But this is why Atom has the high-gain switch, right?
I'm using DT880 600Ohms with Objective2 on the 3.5X gain and it works fine with -1...0dB FS records, but with low-level recordings a powerful headamp might be needed. I would say that Atom will work perfect with your 250Ohms headphones.
Budgeter
Well, it's complicated to say but I actually tried 880 600 or 250 ohms before. As in my experience, even at around 10'o clock, the volume is enough for me since I mostly listen on Youtube, which has pretty high average SPL. What concerns me is the possibility of overriding them, not really the volume itself. As my "educated-guess" above, probably even at 10 mW, the volume can reach really high level already, so there is no concern here (Based on my understanding from Solderdude site: https://diyaudioheaven.wordpress.com/tutorials/power-impedance-etc/ )
Besides, I wonder why amplifier output cannot correlate with position of volume knob? Maybe it is duo to the difference between potentiometer? Because of this, it's hard for me to applied these number in reality. (E.g: 100 mW-600 ohms @ 10'o clock knob, etc, things like that)
solderdude
The Neitherlands
max. output power of an amp depends on max output voltage and current capabilities.
Max output voltage is determined by the internal voltage rails.
Max. output current could be limited by current limiting or other reasons.
The volpot position determines the output voltage.
The headphone impedance the output power at a certain output voltage.
At a certain volpot position a 600 Ohm headphone will have draw much much less power than when a 16 Ohm headphone is connected.
The volpot position to obtain a certain SPL thus depends on many factors:
1: gain of the amplifier
2: volpot taper (log, lin or other variant)
3: output voltage of the used source.
4: headphone efficiency (dB/V) not dB/mW and thus also headphone impedance.
Budgeter
That's a detailed explanation, I get why we can't show power relative to knob position now. But can you tell me why can't we have a voltage output relative to volume knob position? Of course, it will be depended on input source/gain, but I think we should be able to give a spec in term of percentage instead (E.g: 70% of input source x gain @ 12 o'clock, etc).
JohnYang1997
China
That's just voltage gain. Getting high gain is easy just change one resistor value. You do not get more power out of it. It will just clip earlier or plainly not work depending on whether the gain is before the volume pot or after. Power is limited by the power supply voltage for voltage output and output device output current for current output.
