confucius_zero
- Joined
- Nov 22, 2018
- Messages
- 541
- Likes
- 345
has anything surpassed it in every way on single ended performance? I'm not sure...
Just wait for it.has anything surpassed it in every way on single ended performance? I'm not sure...
The Geshelli Archel perhaps?Just wait for it.
EL Amp II?short on power.
Performed the same. So like I said, gotta wait for it.EL Amp II?
Yes you can. But it will make zero difference. There's no basics of electronics that prevents using plastic chassis.Can I wrap my Atom in aluminium foil?
I cannot believe I have bought an amplifier with plastic case. Violating the basics of electronics.
I was thinking about preventing the electromagnetic interference.Since when the electronics are "allergic of some kind" to the plastic?
I've found this. It is okay.RF is still an issue and should be considered, directly on the input connections and through casework. Metal case will perform better for shielding however it should be stressed that the end result, how sensitive the unit is to RF, will depend on many circuit variables and it really is not necessarily true that this unit would have any I'll effects due to a plastic case under normal conditions. Ie not living next to an AM transmitter.
99% of the amplifiers are in metal chassis. So that is for only cosmetics and good-looking?
Have a read:Hello! Can anyone tell me what in terms of performance I am losing if I use Atom in high gain? Do I get much more distortion, noise etc? I am using it with my Beyer DT 990 Pro 250 ohm and I just want to give them more punch and that is exactly what high gain do to them.
Then whatever they say about how powerful and good this amp is, it is not good enough to drive 250 ohms headphones if I must use it in low gain. Some tracks need more power and high gain. :/Have a read:
https://www.audiosciencereview.com/...s/study-headphone-amp-gains-low-or-high.5495/
Conclusion: Don't use high gain unless it's not loud enough with volume all the way up.
Have you maxed out the volume?Then whatever they say about how powerful and good this amp is, it is not good enough to drive 250 ohms headphones if I must use it in low gain. Some tracks need more power and high gain. :/
YesHave you maxed out the volume?
Ok, then you can use the high gain settings.
My Atom is near a similar number of SMPS and it's not too far from the power strip. It's also near the wireless router, power amp and TV. All accomodated on the same rack. No problems in terms of noise. I think JDS Labs knows what they're doing. For me one upshot of the plastic case is I don't get a shock when I touch the unit. Unlike what can happen with my gear in metal boxes.I've found this. It is okay.
Only I living next to 7 cheap SMPS in plastic case.
