JohsonChou
Only thing I don't like about this amp is the volume control. I wish there is a seperate power swtich. I bet a volume pot without power switch would probably has better channel balance at low volume.
This is very clean power man.From what I understand here, @300 ohm the O2 clips at 0.11 watts with THD+N of ~0.0015%, whereas JDS Atom does not clip till 0.25 watts with THD+N of 0.0005%.
TL;DR JDS Atom has much lower noise and much more clean power.
I'd go with both and make a stack out of them. Awesome DAC/AMP combo for $300.This or the DX3 Pro for HD6xx ( I live in Asia so the Atom will probably cost around 150$ as the distributor sells the O2 amp for 150$ in my country ) but I can order the DX3 pro directly from Aliexpress. TY
The Khadas is technically a great DAC for sure, esp for the money, but too spartan for me. I love the features on the DX3. Plus getting a case etc. for it is a hassle, unless one is a hobbyist.or Khadas Tone Board and Atom combo for less than $200.
Shutdown issues? I've had my DX3 for a week, and haven't notice any issues. It does seem to have an auto power off when its not being used, but I think this is part of the normal settings.Have they fixed the shutdown issues on the DX3 yet? I returned mine and went with the tone board/Atom and am very happy.
Another random observation: are the RCA jacks on these oddly loose or is it just me (both in and out)? Gonna go buy new cables because mine are just sliding out every few days.
That's what I meant yeah. Thanks, will try.The RCAs on mine are firmly affixed to the PCB. If you mean that the male RCA connector on the cable is loose on the female connector on the Atom, then try crimping the blades on the male to make them fit more tightly.
I'm sorry for this rather odd outlook but is Atom supposed to be excellent within the sub 500$ price range? As the measurements have shown that it can outperform an amp twice more expensive , or even further .
I got one for myself and i can say that it sounds clean , and gives more than enough power to drive my cans but that's it . I'm not really impressed or blown out at all , is there something i am missing out?
Atom is the first amp i own by the way , and i am pairing it with OL DAC .
I'm using DT990 Pro at the moment , i also have a HD 6XX but my friend is borrowing it so i may give it a try soon . I don't have much knowledge about measurements and technical aspects so i only rate something with my own experience . As far as sound quality goes is there a huge or very noticeable difference if i switch from Atom to let say a ~1000$ amp? ( small example : audiogd nfb )Maybe we set your expectations too high. What headphones do you have? The Atom does everything you need as far as power and transparency. The only reason to get something else would be to have other features, not better sound.
I guess that could be the case , my DT990 sounds much more impactful and a bit harsher than my taste when i plug it in Atom , but since i know Atom is not a colorful amp the only explaination left is this is what those headphones sound like , i guess i'm gonna borrow a few other headphones to test with Atom so i can have a clearer answer .Perhaps you would prefer electronics that produce audible distortion, or perhaps you don't like the sound of your headphones or recordings so much (since, assuming you have a decent DAC, the headphones and the music are all you could be hearing).
Btw , i am bugged with a question : Is there a point in buying very expensive amplifiers ( maybe from 1000$ and above ) if you only aim for sound quality? Because measurement-wise Atom is already so good and according to many people it is doing a good job of what an amp should be doing , and it is only 100$ .
