IVX
but still trivial
tell that to whoever designed the Dragonfly cobalt ...but still trivial
LOL...tell that to whoever designed the Dragonfly cobalt ...
I will be curious to hear from anyone who tests this configuration (2.5mm TRRS to two XLR balanced). I understand that this is going to be a corner case compared to the amount of people who will be using it as a DAC/amp with a portable source but this is my ideal scenario as I plan to use such a device with active studio monitors.I had the same doubt / question after reading @solderdude comment ... but had no time to ask him, thank you for doing that.
Like this: http://www.lunashops.com/goods.php?id=5241
Did they need to? The usual suspects have given it glowing reviews regardless, such as here <http://www.hifiplus.com/articles/audioquest-dragonfly-cobalt-dacheadphone-amp/> (Alan Sircom, what happened? You used to be alright).LOL...
I think it should be whoever is trying to sell the Cobalt ....
The engineers were probably given a fixed manhour budget, and worked accordingly. The marketing guys went bat crazy with the pricing and marketing BS ....
I didn't use an XLR but that is exactly how I tested the unit with my analyzer using its balanced banana jacks. So no reason it would not work.I will be curious to hear from anyone who tests this configuration (2.5mm TRRS to two XLR balanced). I understand that this is going to be a corner case compared to the amount of people who will be using it as a DAC/amp with a portable source but this is my ideal scenario as I plan to use such a device with active studio monitors.
How to deal with separate grounds to a shared one in such a case?Today I received my 2.5mm to 3.5mm jack so now I can use my new USB dongle...the E1DA.
Rollaven
sorry, but you can not use any kind of 2.5/3,5 jack adapters with 9038S, rather you can kill the DAC.
Despite all the warnings lol. Never plug unbalanced in a balanced output port dudes. Things break, if not immediately they will over time....Finally !!
This baby will primarily be used in the office at work with my trusted CL1's. In the back you can still see the trusted work horses Atom and D30, still goin' strong.
The E1DA does the job well and is essentially plug and play with my windows laptop. Thanks @IVX for the fast shipment all the way to the EU.
YeapWasn't about half of this thread about that exact issue?
i think he maybe custom headphone out to balanced xlr cable.Yeap
PS: isn't that an XLR in the picture anyway??? He could have converted to 2.5mm :| I'm confused.
Yes this is possible
R+ to 2-XLR right channel
R- to 3-XLR right channel
L+ to 2-XLR left channel
L- to 3-XLR left channel
