The top graph isn't connected at all )) About "Home DAC" yes, if it is optimized for 10kOhm load, of coarse it suppose to work with some amp.
Homeboy DAC!
I can understand your reasons for not having DSD on your product. However, sometimes the best available version of an album is available on DSD. I have some DSD files and think they sound better when not converted to PCM. To me, any transcoding only makes the quality worse. And I do listen to DSD at home. But DSD decoding is not absolutely necessary for portable use.
DSD files carry high frequency noise inherently due to the conversion process involved in editing. That said, the DSD DAC amirm tested shows better results for DSD vs PCM in terms of SINAD: https://www.audiosciencereview.com/...measurements-of-holo-audio-cyan-dsd-dac.6992/Interesting that most of DACs offer better specs for PCM mode vs DSD, not a big difference but PCM better always.
So many portable devices lack serious PEQ, and personally, when I bought an RME DAC, one of the deciding factors that helped my decision was it's inclusion of something like the 5 band PEQ (wish it was 10, but you can't have it all).
The EQ issue mostly is found on iPhones where no serious EQ apps exist that I know of.
Hi,
Can the E1DA be ordered from Europe, or other site than Aliexpress? For some reason it doesn't work for me.
Thanks
Have you tried the Neutron app for the iPhone?
I’ll leave it to others more knowledgeable than myself to assess how it might stack up compared to the built in equalizer of the RME DAC, but IIRC, the Neutron PEQ can be expanded up to 20 bands.
Pretty damn great compared to $600 singxer sda-2 for example, especially considering the dongle size
Well, seems I finished all that I can on that 9038D proto PCB and it's time order next iteration, I hope the last one. I have to add 4th operating mode into MCU named "Home DAC", where ES9038Q2M will be configured similar to "Performance" mode but with THD optimization for 10Kohm load...
He commented on how the start-up current is a problem with phones. So your experience matches his explanation. I think he is working on a soft-start for his next project.Perhaps Ivan can comment on this, but I need the battery bank connected at first for anything to work, but only for ~5-10 seconds, then I can unplug it and it works fine without it. If I unplug it too soon, the 9038S turns off.
Awesome work, man.Hi, I working on 3.5mm jack DAC #9038D(and 9038S gen 2 as well) DAC in the same case where the soft-start issue solved. It may smoothly start with Android or iOS device without external power but.. due to quite high output power, my iPad Air2 switching off its USB power as soon I increase player's volume. My Android behaves even worse, it can reset itself in case if its USB consumption too much. Hence, the problem with an external power source is not solvable principal, without Li-battery inside of DAC. Yesterday I googled for "USB DAC requires camera adapter" and the first what was found is dragonfly cobalt! Even such a tiny power DAC requires the Y-splitter(that the "camera adapter" is but from Apple and 10x more expensive). What we can expect from 10-20x more powerful 9038S/D? BTW, I prepared the additional operating mode for 9038D/S_gen2 called "IEM" mode, when the output power will be limited at -15dbfs for safe operation with insane low IEMs up to 4ohm(200mW@4ohm THD<.0015%).
