You know, it's funny.
My subwoofer comment was vague enough to mean various things, I suppose, and
of course lots of people decided it meant something heretical.
Relax, I don't have any opinions on audio that are so interesting. Although the tendency to dogpile on ASR can be a bit interesting.
We shouldn’t have to explain again and again in an objectivists audio science forum, why multisub+room Eq is mandatory for proper bass reproduction in rooms.
Where is the evidence that integrated woofers produce better bass than subwoofers? This isn't sarcastic, I'm truly curious. Because as far as I know, it's the opposite. Subwoofers require more work and you need more than one for the best results, but as far as I understand it, it is physically impossible to produce bass
on the same level as this with ANY two speakers no matter how "high-end".
First, I should start by saying that my main music system has dual subs and EQ.
There is no disputing that if you want accurate in-room deep bass, such as the immaculate waterfall graphs down to ~17hz that you linked to, then you need to bust out the multiple subwoofers. It's basic physics. There's no other way. As
@Dimifoot wrote, I too hope that it is basic foundational knowledge in this hobby or at least on this forum.
That all said...
That said, a customer buying $16,000+ speakers probably doesn't want to be told "oh you also need a modern room EQ system, DSP, and 4 other boxes to get good results". Even though that is probably what they do, in fact, need.
Need? I certainly would not agree that subs are necessary or even ideal for "most" music.
Strong bass down to the 30-40hz range is deep enough for nearly all music, and a lot of music doesn't need bass reproduction
that deep.
Finally, there's the matter of budget. A multisub+roomEQ setup with subwoofers capable of accurate deep bass is not cheap. It certainly can be done cheaper, particularly if you're going DIY or buying used, but multisubs+EQ is generally going to start out at around $1K at retail and obviously can cost much more.
Unless their overall budget is so large that a grand or two is insignificant,
most people would be
generally better off spending an extra grand on their treble and midrange (you know, where the music actually lives) than dumping all that money into the bottom octave alone.
As
@amirm said, a speaker like this Revel that can cover that range and do it well, is going to sound great for nearly everything.
As for EQ? Well, I don't think it belongs in this discussion. If you want accurate in-room response, it is a requirement, and that is particularly true for bass. But that is equally true either with or without subwoofers.
