dshreter
- Joined
- Dec 31, 2019
- Messages
- 967
- Likes
- 1,591
Running dual subs in stereo is probably a bad idea.
Most of the time you are going to have a similar bass recording in both channels - for the same reason bass is difficult to localize, if a performance is recorded with stereo microphones, they are likely to "hear" pretty much the same thing during recording. So if R & L channels are similar, running in stereo will be functionally similar to running mono.
In the case where the right and left channels are different, it would be actively detrimental. Let's set as an extreme example that in production a bass guitar track is panned hard left and vocals are panned right. The bass frequencies of the bass guitar would all come out of the left subwoofer in that case. However, the primary reason you purchased dual subs was to even out the in-room frequency response. If all of the bass is coming out of the left subwoofer, you'll be left with the same peaks and nulls in room response as if you had only one subwoofer, and defeated the purpose of what you initially set out to correct.
Because bass is difficult to localize and not part of "imaging" so to speak, we can take advantage of that attribute. That lets us choose the sub location more flexibly based upon the in-room frequency response or deploy multiple subs for even further gains in response, without deteriorating the imaging performance of the system.
