Revel F208 Tower Speaker Review
Based on this, it appears that Revel subs are not the best value. https://www.musicdirect.com/equipme...lZMAHHue-kaGrNWoQq6O518E8bUwesRxoC5G0QAvD_BwE
I don’t know if there is a lot of R&D that Revel put into the subs like they put into their speakers.
At one point they were using a modified JBL driver for their 15" subs (SUB1500) and they were beastly... Except when the failed, which was common when pushed and had something to do with the lead leads and hitting the driver at extreme excursion.
Thank you for this info. Here is a JBL subwoofer that very similar to the Revel. Looks like they just rebranded a JBL sub or vice versa so whatever this means at face value.
I’ve never owned a Revel sub. I would have liked to have gotten the Rhythm at close out but I missed out….I think that was a pretty good sub and would have been a good alternative to my Gothams.
I believe Harmon does provide the drivers, speced for Revel and the 15" I referenced in my first post was used in a JBL Synthesis line for a couple of years. It was passive with an out board amp.
My Rythmic distorts about same as all the others. I turned it off.
Curious as to when and how you hear this distortion?
At very low HZ, very loud levels, what's going on?
Never owned any but Rythmic's are quality products and shouldn't be creating audible
distortions unless something isn't right.
I've had Rhythmik subs bottom out or distort on some movies. Never with music.
If your subwoofer badly distorts there are 3 likely reasons.
1 It's a really cheap POS (not yours)
2 It's been incorrectly set-up.
3 It's too small for your needs. (the most likely).
First thing you need to do is determine your needs.
1 How low do you want it to go.
2 How loud do you want it to play
3 How big is your room.
Once you outline your parameters I'm sure you can find a great
sub that doesn't distort from any of the major manufacturers.
I have 2 SVS SB2000 here and I've never heard it make any audible distortion
that wasn't on the source.
If you want Revel, I'm sure your can find one from them that will meet your needs.
They tend to be a bit pricey but they are a top quality product that is also very attractive.
Just like all other speakers, your gonna pay extra for that furniture quality finish beauty.
Here's a couple links that might help you make your decision.
Our member here @sweetchaos has done a lot of work puttinng together some charts.
The guys at Audioholics have measured and reviewed many, great reference material.
I know. I have corrected through Anthem Room Correction. I suspect my personal preference. I don't like the rumbling.
I don't play load. Just doesn't sound clean to me.
They are expensive compared to SVS and Rhythmic.
Very expensive, but they are very purdy.
To tell the truth it's hard for me to be objective here.
They're way above what I'd pay for a sub, considering the super excellent products being built by the others for much less.
I do believe your looking in the wrong area to cure your audible issues unless your overdriving the crap out of it
or it's been damaged.
Best of luck.
That is the mystery. Cannot find any objective measurements. Sure wish Amir would measure one. They are expensive compared to SVS and Rhythmic.
Mostly a waste of Amir’s time I think. I’m sure these subs measure just fine. $3k??? I suppose Revel can charge that much to people with enough money that the logo on the sub matching their bookshelf speakers is important.
I've not looked for Revel's, but www.data-bass.com used to have lots of basic measurements of subwoofers.
I think I understand what you mean. I still have a SVS SB13-ultra and had a PB16-ultra but neither sub gave me that satisfying bass that my JL F113 did (which I’m listening to right now in my 2nd system where the JL is the star) or the Gothams that I have in my primary system.
No matter what I did with the SVS subs, I just wasn’t 100% happy. It could be setup related too but I’m happy now so it’s all good.
Not sure there Revel subs will get there for you but who knows…maybe someone will test them (Amir or anyone else).
The cheapest.
So an L12?
A comparable Revel sub may or may not offer objectively lower distortion, but even if it did, would you hear it? I would highly doubt it as what you seem to be describing does not hint at audible distortion, but points much more to setup/configuration/room issues. But as you appear to be somewhat averse to providing details on your room and setup, all anyone here can offer is conjecture.
The cheapest.
I believe it's highly possible you could replace the L12 with a Revel and still have the distortion do to your
DRC calibration attempting to correct for a large dip in response due to room mode. Have you tried the usual
stuff like moving the sub somewhere else and re-calibrating? There's just too little information here to really
dig into the problem..
For what the Revel costs, you could buy 3 more Rythmics and after calibration reduce the current distortion in
the order of 12db if my old brain maths correct.
Just a thought.
So an L12?
Yes
Thanks. Haven't moved yet. Need to rewire.
Just a thought.
60 years ago I was informed by a well informed source that 2% harmonic distortion of 30Hz, being 60Hz, sounds louder than the fundamental 30Hz.
No wonder that there seems to be no audible difference since all are hearing the harmonics and not the fundamental bass.
There have been speakers (e.g. the 15" Karlson) that could reproduce at very low distortion - it was not heard but only felt.
