Can you specify your answer a little bit more, lol?It is complete and utter bullshit.
Brandolini's Law. When something starts with this, you know you're in a morass of idiocy and it's not worth reading further.Can you specify you answer a little bit more, lol?
Probiert man verschiedene Bananenstecker am gleichen Kabel, so wundert man sich über die großen Klangunterschiede. Auf Grund solcher Erfahrungen habe ich immer den mit Silberlot fixierten und gegen Oxidierung relativ gut geschützten offenen Leiter empfohlen, der direkt unter den Schraubklemmen der Verstärker und Lautsprecher geklemmt wird. Dies ergab oft genug drastische Klangvorteile gegenüber attraktiv aussehenden vergoldeten Messingbananen mit federnden Kontaktkörbchen.
The measurable differences with steel are about 3 orders of magnitude below any plausible audibility limits.lol...
I agree with @SIY. The premise of the writing leads down a path of expected certainty on the topic and that's not what most people hear when they change to copper banana plugs. The chain of the audio path makes a difference in whether you notice any difference with solid copper/silver banana plugs versus magnetic plugs.
For instance, if your amp has steel connectors feeding the banana plug on the amp - don't expect a new copper banana plug to make an audible difference. The only time I notice a difference in sound when using copper banana plugs is when the audio chain from the amp to the speakers is also using quality non-magnetic connectors. In that case, the upper treble range may be enhanced when playing music with lots of percussion (typically cymbals).
Look for non-magnetic banana plugs when making a selection and you will be fine. If you do try more expensive plugs be sure they have a an excellent return policy.
Maintaining contact over time. It's possible, but you want a fairly gas-tight connection and that means clamping down hard.Thank you. So, what about connecting the bare twisted cable to the speaker and securing it with the screw? Any downsides coming with that besides "damaging" the strands?
Thanks for the advice. Keeping in mind what Roland68 allready posted I asked at distrelec (distributor of Stäubli) if the connectors are free of any magnetic materials but in the end they told me to connect with specialists at monacor international for further details of coating...lol...
That superstition is making life difficult for you.I asked at distrelec (distributor of Stäubli) if the connectors are free of any magnetic materials
Thanks againMaintaining contact over time. It's possible, but you want a fairly gas-tight connection and that means clamping down hard.
Well I am not superstitious. Like I still use a simple Oehlbach Kabel I purchased decades ago with my Rotel amplifier which unfortunately did not make it that far. It is just difficult to distinguish between science and myths and there are lot of oppinions and options about connecting speakers even in this thread.That superstition is making life difficult for you.Seriously, worry about stuff that matters like mechanical integrity.
My favorite is the guys who are freaked out about magnetic materials in the resistors or capacitors used in their tube amps. You know, right near the tubes and transformers.
Banana plugs are mostly for convenience and aesthetics. Unless they're damaged or severely flawed, impact on sound should be close to 0.Thanks again
Really, thank you for explaining what matters in terms of connecting,
Magnetic materials in transformers? Hooda thunk?That superstition is making life difficult for you.Seriously, worry about stuff that matters like mechanical integrity.
What do you think?
audiojudgement.com
Can you give a TL'DR of the results. Did they actually do any measurements showing impact on the audio signal at the speaker?A discussion with some friends made me look at these posts where someone tested several banana plugs for resistance to find out which ones might be best to use:
Ultimate Banana Plugs Buyer's Guide - Audio Judgement
Reviewed 18 pairs of banana plugs from cheap to expensive. Stay clear of the ones which don't perform and see which one has my recommendationaudiojudgement.com
YouTube:
This article leads to the Excel Spreadsheet with the results:Can you give a TL'DR of the results. Did they actually do any measurements showing impact on the audio signal at the speaker?
Because if it is anything other than "The small resistance differences measured are not enough to give an audible difference in sound"
it is almost certainly nonsense - assuming none of the plugs were broken by design.
audiojudgement.com
In any way, going back to SP cable terminals/plugs, I continue to stick to the really cheap non-magnet tin-electroplating pure copper (industry use) crimp terminals (about USD 6.3 = JPYen 900 per 100 pcs box!) together with very cheap heat-shrink insulator covers (USD 7.0 = JPYen 1,000 per 10 m!) which I use only 2 cm for one crimped terminal; (ref. #62).![]()
Modified my post slightly, following the link from @Sokel, since the results in the spreadsheet are useful for identifying those components of inadequate quality.Can you give a TL'DR of the results. Did they actually do any measurements showing impact on the audio signal at the speaker?
Could be useful for identifying inadequate quality components.
I can’t tell if all the tests he did are ultimate for final word, but I thought it might be a good starting point at least.Can you give a TL'DR of the results. Did they actually do any measurements showing impact on the audio signal at the speaker?
Unfortunately test test protocol is only hinted at in the video, but text description.This article leads to the Excel Spreadsheet with the results:
He used normal 4 point Kelvin connection to measure just mOhm at start but because the (otherwise nice) tolerance of the DMM did not allow such precision he switched to feed it a constant 1A current and measure the voltage drop across the connection.Unfortunately test test protocol is only hinted at in the video, but text description.
