The Transducers' Voice Coil
smowry
Phuket
The most advanced magnet wire that never was is Rectangular Anodized Aluminum Clad Copper (ACC). The primary reason is the lack of demand from the loudspeaker industry. The Aluminum Oxide Insulation layer will not melt below 2000 degrees C and Aluminum has a melting point of 658 degrees C. Anodized Aluminum Coils can survive temperatures of up to 500 degrees C for extended duration. In contrast conventionally insulated Aluminum or Copper Wires have a max operating temperature limitation of 180 degrees C – 240 degrees C for polyimide enamel. Copper Clad Aluminum (CCA) magnet wire is commonly used to realize audio transducer voice coils. The most desirable characteristic is that it's a low mass magnet wire that can be soldered to braided lead dress wires typically called "tinsel."
The Type I (Chromic) anodizing process forms a thin layer of Alumina (ceramic), roughly 2.5 µm (0.0025 mm) thick. In contrast enameled magnet wire insulation is 0.06 to 0.11 mm thick. Additionally, the anodized insulation has high thermal conductivity, 30 to 35 W/mK. In contrast enameled insulation has a thermal conductivity of about 1 W/mK. In effect the anodized insulation is inert. However most importantly is the differences in "Packing Factors." Rectangular wire with anodized insulation is the SOA for voice coil products. BOSE Corp. was the first to use Rectangular Anodized Aluminum magnet wire for voice coils. One problem with Anodized Aluminum magnet wire is that it cannot be effectively soldered. BOSE addressed this problem by using mechanical wire crimps to terminate the Anodized Aluminum magnet wire to the tinsels. Anodized Aluminum Clad Copper would offer a solution. The ACC wire would need to have the aluminum cladding mechanically stripped but then soldering would be conveniently facilitated. Winding rectangular wire works best in a single layer. Voice coil winding companies have developed the ability to wind a single layer of wire on both the inside and outside of the voice coil former or bobbin and this avoids any wire crossover that would require a grove the the motor assembly's gap plate. This was how BOSE addressed the crossover issue. The inside | outside winding inherently removes the need for for a wire crossover. Another issue with a single layer voice coil is low resistance, Re. The inside | outside winding would effectively double the wind length and thus double Re. The BOSE 901 transducers were about 0.7 ohms DC, where 9 x 0.7 = 6.3 ohms (series connection). BOSE disclosed their helical voice coil details in their 4.5 inch transducer patent filed in 1976 (49 years ago), in US4061890. Frankly speaking that voice coil was superior to anything being used today. The Anodized Aluminum wire was manufacturer and supplied by H.P, Reed Co. I believe that they went out of business and were subsequently sold and they no longer offer Anodized Aluminum magnet wire.
The technology to clad copper with a thin layer of aluminum has existed for more than 60 years. US2947069, filed in 1956, reveals the secret. I can remember reading about the ACC voice coil development back in the day. However, I can not identify sellers of Rectangular Anodized Aluminum Clad Copper (ACC) wire today, never mind voice coils using it. The crimping process on Anodized Aluminum wire and foils has been accepted by magnet coil manufactures and some use welding to terminate their coils. The added crimp's dead mass is not an issue for them. Crimping audio transducer voice coils adds mass that serves no purpose other than to connect and can be related to a failure mode(s).
The last BOSE transducer to use the single layer Anodized Aluminum helical voice coil was Manta. A reverse motor super slim woofer that was developed just before I went to work there. BOSE's cost to manufacture the Manta voice coil in 1998 was US$10, which was considered very high back then. At that time the NdFeB magnet was being imported from Germany's Magnequench. Cost concerns killed the highest performing voice coil in the industry.
Note the small Neo motor in the front in the picture below and the dust cap on the center of the spider in the picture above. Manta was invented by James Scanlan from MIT, the Transducer Engineer that I replaced in 1995. The patent related to the diaphragm attachment to the frame, US5625701. Jamie Scanlan was a student of Dr. Bose at MIT. When he interviewed me in 1995, he told me that I would last about 3 years. I lasted just about 3.5 years before moving to San Diego to join Thilo and his mother at TC Sounds. Jamie visited me in Thailand a few times after I left P.Audio in 2002. After his last visit, I moved from Bangkok to Phuket and I have not seen or heard from him since. He now lives in San Francisco and does software. Frankly, he was a super smart guy and his eyes seemed to sparkle through his glasses back then. That was the guy I was expected to replace. Five years before that, I was driving trucks for UPS. When I got to BOSE in 1995, I was like a hungry animal in a technical sense and there was plenty to eat!
Manta came in 8, 10, and 12 inch versions. Nominal impedance was 2 ohms and all versions used the same spider, dust cap, voice coil, terminals, and Neo magnet assembly. Only the frames and cone/surround assemblies were different. There were two frames sandwiched. One to fix and support the motor and the other to fix and support the soft-parts. The design was well received throughout the company.
So then the most advanced voice coil possible for audio transducers would be an update to Manta's but wound inside | outside with Rectangular Anodized Aluminum Clad Copper (ACC) magnet wire. Then why is no one doing this?
1. No patent - The coil concept is public domain and unfortunately the loudspeaker industry is patent driven. Similar coils are available; this would be a wire update.
2. Cost
3. Specialized winding processes that include the need for an induction heater(s) to activate the polyimide adhesive coated former during winding
4. Industry attitude
What is the most important component of a moving coil audio transducer? Many transducer experts would reply, the voice coil.
On another quasi-related topic, "How many Patents does BOSE Corporation have?
The more patents a company has, the more money they can borrow. Although BOSE can be innovative, where's the beef?
Note BOSE has a team of attorneys on staff that are ready and able to prosecute any perceived infringement. BOSE is a company that understands restraint of trade and how to implement such within the loudspeaker industry on a global scale. Fortunately most of their good stuff was related to patents that have expired.
Hello Steve. You have not addressed the wire bonding material. It's wonderful to have an anodized insulated wire. What keeps them bonded in a coil? And what is bonding the coil to the former? That will be the weakest link in this system as it is in any voicecoil wire bonded into a coil form. The adhesive.
The voice coil is held together with polyimide that is flowed with an induction heater during the winding process, hot winding. Such wire is typically wound on an Al bobbin. This type of voice coil was used in early BOSE 901 and Manta transducers but was pure aluminum magnet wire. The same insulation and bonding processes could be utilized for Al clad Cu magnet wire.
Note that Beta = (B^2)Volume of conductor/resistivity (N^2/W)
The voice coil is held together with polyimide that is flowed with an induction heater. Such wire is typically wound on an Al bobbin. This type of voice coil was used in early BOSE 901 and Manta transducers but was pure aluminum magnet wire. The same insulation and bonding processes could be utilized for Al clad Cu magnet wire.
So no higher heat capability than a good polyamide bonded copper wire. Or CCAW. THat explains it's not really being in use now. The idea of anodizing is interesting. But wouldn't you get cracks as you wind the wire into a coil? It is an aluminum oxide ceramic after all. So you are still depending on the insulating properties of the polyamide, which is very good.
Like the crimp solution for the connection That is brilliant for the quantities of drivers Bose was making.
Mark
With respect to polyimide hot winding magnet wire, https://craigwire.com/cw-240ml-magnet-wire/. This is class 240 degree C wire but without anodized insulation. And yes, the Voice Coil that never was would be class 240 degrees C due to the polyimide. However, it is not in use due to cost and complexity of process. The point is that the anodized insulation is very thin and allows more conductor in the gap for a given coil OD.
Please name any manufacturers that are using class 240 C voice coils without anodized insulation because I don't know of any.
I'm working on a high temp subwoofer voicecoil right now actually. A few manufactures can wind using this type of polyamide. Hot setting if I remember correctly. The voicecoil is warmed up above the partial melting point of the insulation layer and they bond to each other. Generally a well timed and controlled DC current to do the warming up. Setting to the former can also be done, depending on the former material.
Mark
Polyamide is a type of Nylon and is typically used with Class 220 degrees C. It is also hot wound.
I think we both missed the primary point of the thread the second time around. The single layer anodized wire has no bond coat. The polyimide is on the Al bobbin only. The 240 degree C wire available today uses polyimide as both insulation and bond coat but can be wound in several layers. The difference is then not the temperature class but rather the packing factor. The anodized insulation magnet wire without any bond coat can only be used in single layer topology. This is why the single layer BOSE 901 transducer's 1 inch voice coil was 0.7 ohms DC. A large subwoofer single layer or better yet single inside/outside two layer coil could be 4 ohms nominal.
There is at least one company using single layer anodized aluminum magnet wire voice coils. From the TAD website, https://www.technicalaudiodevices.com/pro-hf-units/:
"A voice coil of edge-wound wire made of anodized pure aluminum is used. The conductor occupancy in the magnetic circuit is increased to the utmost limit to achieve high efficiency."
@smowry , thank you for these interesting industry insider insights.
Personally, I'm wondering at which time in the future 2-component 3D-printed VCs will appear, making one single integral VC+bobbin part. Multilayer should be possible as well as it would be much easier to implement variable pitch (to linearize BL(x)) while maintaining maximum packing factor.
Note that the variable pitch VC trades packing factor for BL(x) linearity. A decades old alternative approach is to utilize a closed loop control system to maintain BLi(x) linearity.
To the best of my knowledge, the first company to use a variable pitch voice coil in an audio transducer was TC Sounds in ~2006. Thilo along with Vannin Gale, Senior R&D/Marketing Manager of Eclipse, were responsible for the concept development. Thilo discusses such a voice coil at 2:00 into the 2010 Parts Express video below.
Here's some information on the TC Sounds LMS subwoofers (LMS => Linear Motor System). https://www.audiosciencereview.com/...t-and-boom-from-the-past-tc-sounds-tc2.50284/
The Eclipse LMT SW8200 also used a variable pitch voice coil (LMT => Linear Motor Technology).
Packing factor is best either with square wire, or rectangular ribbon wire. If you are trying to squeeze every last bit of performance and cost is not an issue, this is a route to choose.
Secondary issue is a much wider gap than you are normally requiring and therefore a huge penalty on motor efficiency. It is an interesting idea. But as a useful concept, unless you are routinely driving your woofers to near their X-max, it is a worthless option considering what you are giving away in system efficiency due to the overly wide voice coil gap.
That's why changing the geometry of the wire itself would be an improvement, with a rectangular wire with constant width but variable height cross section. That would allow for fully maximized copper mass in a gap of given width.
I would be interested in how you think that you would accomplish this. I can think of a few ways to draw the wire. To wind it is another question.
I am not sure that this would be effective. Yes L(x) would vary but remember that in effect the coil is a flux integrator. The true figure of merit for the motor assembly is Beta.
Beta = (BL)^2/Re N^2/W
Re = (rho)L/S ohms
Where S is the cross section of the wire m^2
rho is the resistivity ohm m
Then Beta = (B^2)LS/rho
But LS = Volume m^3
Then Beta = (B^2)Volume of conductor/rho
L relates to Re; however, Beta is related to the Volume of Conductor. The amplifier, typically a voltage source, sees the entire coil regardless of pitch. Thilo's LMS voice coil varies the Volume(x) in the gap and thus Beta(x) is linearized. Note that BL alone is a meaningless parameter, while Beta considers both BL and Re and is the true figure of merit.
Transducer A has a BL of 10 N/A
Transducer B has a BL of 8 N/A
Now which motor is better?
Transducer A is 6 ohms DC.
Transducer B is 3 ohms DC.
Answer is transducer B!
What we need is the ability to commutate the voice coil.
Fundamentally the voice coil remains unchanged since the invention of the moving coil audio transducer more than 100 years ago !!!!!!!!!!
3D composite (multi-material) printing the whole thing what was VC and bobbin in one go, will be possible (and cost-effective) sooner or later.
Full Ack. I always use (BL)^2/Re as the figure of merit (I'm using capital L because of font issues). The point is that only part of the conductor length L, the part which is currently in the gap (+fringe field), contributes to the force. By increasing L at the ends of the coil the drop of B because part of the coil is about to leave the gap can be compensated. That's at least how I understand it works. With a constant height rectangular wire one would increase pitch (reduce conductor mass per volume unit) in the center of the coil but one could avoid that by changing the wire height itself, keeping mass per volume unit constant.
Yes. When I was in the speaker (not: driver) industry, I had talks with driver design engineers if a segmented VC is possible in an attempt to energize mainly those parts of an overhung coil that really are in the gap, with the driver cone having a position sensor and a velocity sensor, both being used for motional feedback and the distribution of the signal to the segment amplifiers (even with inverted signal to provide strong EMF brake "end stops"). It remained a pipe dream.
