For reference, if anyone is interested, the data provided on the GedLee website is made by best fit calculation of radiation modes, like Klippel's NFS but in 2 dimensions rather than 3.
The measurements from GedLee's website are not comparable to the NFS measurements in terms of resolution and accuracy.
Like all measurements in small rooms, reflections are suppressed using gate/windowing.
This leads to a decrease in resolution below around 2kHz and severe smoothing (1/1 oct) around the lower cut-off frequency (usually in the 200-300Hz range) of the gated measurements.
If I have understood correctly, the frequency response and radiation are simulated/calculated below this cut-off frequency.
There are only measurements for horizontal radiation. The sound power response and DI shown also only refer to the horizontal plane and are not comparable with the CTA-2034 diagrams, which always consider horizontal and vertical planes in relation to SP, ER, PIR and DI together.
The calculation of the DI is also not comparable, as in the CTA-2034 results the DI refers to the difference between listening window and sound power response (hor + ver data). Whereas Dr. Geddes uses the difference between horizontal sound power and a specific hor off-axis frequency response (20° for the NS15) as DI.
So please keep that in mind when comparing the measurement data and diagrams of the NS15 and other data and diagrams based on NFS measurements.
