Here is an excerpt of the Logic that is going on over at PSAudio from Ted Smith:
https://www.audiosciencereview.com/forum/index.php?attachments/1646983316097-png.191680/
"There is no argument that you can make that red is green that's convincing"
Ted needs to broaden his understanding of human perception. We do not remotely come close to passively processing data from the physical realm around us, instead we actively construct our perception from maybe 10% of actual real physical data from our senses. Apparently Ted has never seen an optical illusion or even an auditory illusion. Our survival as a species is from the efficiency of this system, we use old data to process and interpret the little information we are actually processing. To anyone that thinks their senses are a perfect "window" into the physical realm you are grossly mistaken, your senses should never be trusted. Prior information will be used to construct your reality, hence bias when you know you switched a component.
Here is a great video from my friend whom I adore that explains this concept with examples. One example is with the auditory stimuli, you hear what you want to hear via information you have prior to processing the data, if you are thinking of "green needle" you hear that, if you're thinking "brain storm" you hear that. Play this clip for two different groups but only tell them one of the possible wordings and they will go online and argue to death that the clip says one or the other when in fact the audio clip can be both depending on the minds bias. Back to Ted's quote, there is an optical illusion where a mirror image of mountains contains no color, yet if you stare at color long enough your brain will use this prior data with the processing of the mirror mountain image and so now they are colored red and green yet in reality there is not color, your mind added the color from prior information. So Ted do you still trust your senses? If so you are a fool, no offense. The people that swear up and down they hear a "huge difference, so much the wife even heard it from the other room" are in denial that they can never be precise test equipment that passively process and show us data without bias and serious error from our own brains. They just cannot accept the fact that they are not precision equipment and their perception is not able to make objective conclusions.
