You think?Your sinewave is flattened a bit (a few V) given the amount of odd harmonics.
You think?
Yup -- altough not at the peanut level of, say, a 60FX5EL84? That's a little peanut pentode.
What was the Output impedance for this Test?To determine the filter range, I set my Audio Precision to produce 21 volts output and captured and plotted that using very wideband response (1 MHz). I then inserted the Harvester in the middle to see the effect:
How musch of this distortion comes from the transformer?result in a THD+N of nearly 3%.
So before the test you thought. the company that sells 500$ gold plated TOSLINK opticlal cables is legitAudioQuest again in the future. Audio companies that put out pure snake-oil products, even if they produce some other good equipment, are companies I want to avoid.
this is quite important to note.From memory I think it is 40 ohm. I thought about that after I wrote the review.
Tasty BerylliumPure copper is too soft to provide good contact pressure. It needs to be alloyed with something to make it springier.
Common sens can tell from fear mongering marketing this is snake oilI would be interested to hear opinions on this solution, both the tester and the filter.
We want a large flywheel on the rotatary converter would expensive ebony hardwood do or should it be cast in bronze or tungsten ?So before the test you thought. the company that sells 500$ gold plated TOSLINK opticlal cables is legit
40Ohms is little bit more then the typical power grind (at least here in Europe)
With REW you can easily make impedance vs frequency measurements with the help of a known resistor
Tasty Beryllium
Every true audiofool knowes a Rotary converter is the propper way to clean up your AC!
1 ton of spinning mass per amplifier RMS Watt is sufficient.
I use this for my headphone amplifier :
Neutronium, preferably with the mass of a small planet.We want a large flywheel on the rotatary converter would expensive ebony hardwood do or should it be cast in bronze or tungsten ?
Rotary converters are not good at producing low noise DC!need several rotary converters for 5v 3.3v +12,-12 etc
The converters for the left channel should obviously rotate anticlockwise. Except down under, where it's the other way around.You could use sevaral of them in series AC to DC to AC to DC ..... and ofcourse you rip out all of the internal DC/DC converters normal rectifiers and stuff in your DAC so now you need several rotary converters for 5v 3.3v +12,-12 etc . And of course left and right rotary converters . for each component pre amp power amp etc
never.When do you guys learn... you have to listen and hear the improvements... not look at graphs !
Apologies if this has been suggested before, but given that it the harvester has a blinky light to show it's "cleaning" the mains, has anyone tried one on perfectly clean mains, perhaps by plugging it into one of PS Audio's own regenerators, or an isolation transformer, something like that?
Does the light still blink?
I retailed home audio for 9 years and the customers heard what they where told to hear and what they where told not to hear. I sold on the merit of the product and quality but some salespeople did not.I suppose if you can hear something because you expect to then you can also not hear something when you expect not to.
Greg, I am sure you have heard audiophiles many times say, "I heard a difference even though I did not expect to hear it!" The power of the force is strong with tweeky audiophiles!I suppose if you can hear something because you expect to then you can also not hear something when you expect not to.
