- Joined
- Oct 25, 2019
- Messages
- 11,175
- Likes
- 14,882
Sheesh. I said it was a guess. Trolling much?
Probably needs a poll of the poll population
You made a guess, I made a guess, pkane made a guess, jimbo made a guess ...Sheesh. I said it was a guess. Trolling much?
You made a guess, I made a guess, pkane made a guess ...
A massive troll invasion indeed
@pkane would you care to post a result interpretation? Even if you think the poll/options sucked.
After all, you are ASR's foremost expert on HD. Or, at the very least, you generated more HD than anyone around here could ever dream of
I'm by far not the "foremost expert on HD"
My response to the first "100% Right" answer is that this depends on what your goals are. Certainly from an engineering perspective, lower distortion is better. From a personal enjoyment perspective, there's nothing that says that I must enjoy only the most pure, the most undistorted sound. Intellectually, that's what I strive for, but then I apply a room correction curve that I enjoy and find pleasing.
The "somewhat right" and "somewhat wrong" to me are the same answer, and since I can't pick both of them, I didn't pick either.
This left the final answer, "100% Wrong", which, by process of elimination is the correct answer But, it also makes sense, since the poll statement of "Is no-distortion (or below audible limits) always better for music playback than any distortion ?!" is wrong, simply because the word "always" is in it, and as stated before, it's not always true.
Of course the question is begged---who has heard music reproduction devoid of distortion? Unless one has heard such [mythical] gear, answers are not possible.
Was the thrust of my "don't know" responseOf course the question is begged---who has heard music reproduction devoid of distortion? Unless one has heard such [mythical] gear, answers are not possible.
Interesting point about room correction as distortion. With that assumption, "no distortion" has zero chances for the "100% right" medal . Wonder if anyone did vote using that assumption.I'm by far not the "foremost expert on HD"
As I said in this post in reference to James Johnston's definition, distortion should refer to nonlinear modifications of the signal. I don't think many people would consider a room correction curve as distortion in common parlance either.
It's 'begged' in many other ways too.Of course the question is begged---who has heard music reproduction devoid of distortion? Unless one has heard such [mythical] gear, answers are not possible.
My point wasn't that room curve adds non-linear distortion products, but that an altered reproduction isn't necessarily bad, and is often preferred.
It's just an opinion poll about D. It's NOT supposed to prove anything about D, just gather opinions.From what I know about statistics, you are using categorical data to measure preference. It will not be scientific to use this poll as evidence of the causation of anything. Also, it will be subject to the most basic hypothesis testing even before considering causation, and that only helps us to get closer to prove correlation.
Right now, I'm listening to I-Tunes Apple Lossless files via a cheap [Acer Aspire 5] laptop into Topping E/L 30 combo, finally Drop 6XXs. And the level of distortion is lower that what I'm used to, what I've heard before. I am really used to a lot of distortion artifacts, having listened to so much obviously compromised gear all my life. But I also know that the gear I'm now listening to so happily is still distorting. As far as I can tell, all transducers audibly distort.It's 'begged' in many other ways too. And generally there are no perfect Qs. Or answers
That sounds like utter nonsense.Nope, plenty don't distort audibly. In fact, just $5 will get you the Sony MH755 earphones which don't:
I'd say so too... As far as I can tell, all transducers audibly distort.
