Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,303
- Likes
- 5,549
Price is $32K
That should be adequate.
But if you have witches, you can put it on top them and use the thing as a press to extract their confession.you can buy 18-21-24 inch drivers and make more powerful subwoofer than this, size matters I don't care about 400 lbs enclosure
Does it need to be inhaled as a vapor or ingested as a solid to be toxic?There's nothing toxic about a beryllium tweeter until you break it
Which is exactly what happened to mine even though I had paid Alon 5000 to make aluminum grills to protect the tweeters. I waited 2 years for the grills. They were not secure and they made the speaker sound horrible.There's nothing toxic about a beryllium tweeter until you break it
It's like a 250lb aluminum enclosure, lol. Magico's overkill-does-not-exist approach to engineering is fun, but also silly. Remember, for best in-room response you're going to want multiples.
Does it Implode after a few uses? Bad timing with the name.
Or perhaps if the tweeter is smoked???Does it need to be inhaled as a vapor or ingensted as a solid to be toxic?
Hehe. I was equating it to like mercury which needs to be inhaled as a vapor/gas because swallowing it does little to nothing UNLESS it has been pre-digested by a organism and made to be a part of the protein. Alright going to read about beryllium now...Or perhaps if the tweeter is smoked???
Did they put an Adire woofer in a 350 pound cube milled from solid aluminum?
My case is unusual as my son has special needs. This was clearly communicated to Alon and it was explained to him that I would not be interested purchasing his speakers if he could not provide grills to protect the drivers and more importantly my son.when you brake it dont inhale it. it,s one of the most toxic chemicals around.
