NEUMANN KH750+KH120 II+MA1 DSP NETWORK ISSUE
morallygray
Hi!!!
I need some help
I’m trying to set up my new KH120s + KH750 and MA1
I’m on Mac
the Neumann control app detected the devices, but from my understanding I need to use the MA1 alignment for calibration. So I launch the MA1 alignment software and the devices are not detected at all.
I connected the speakers to my router via Ethernet cables through a switch.
I tried to reset the speakers.
Please help I don’t know what else to do.
Hi!!!
I need some help
I’m on Mac
You need to do Mac->Switch->Speakers. A local network.
I tried going out of my MacBook via Ethernet (LAN out of my MacBook Pro dock station) into a switch into the speakers. The new connection shows up in Mac’s Network preferences as UBS/LAN connection, then I select that in the MA1 setup (instead of wireless lan or Ethernet en4/en5en6) but the MA1 freezes and have to force quit it!!!
I'd try a simple USB->RJ45 adapter, instead of a full dock station.
They're inexpensive, and you'd only have to use it once for calibration.
Afterwards you can go back to the dock.
Ok ordered one adapter usb type c to Ethernet like you said.
I will connect the switch to the adapter then the 3 speakers to the switch.
What connection would you select in the MA1 then?
Oh and by the way, thank you so much for answering and giving me something to try!!! I really appreciate it man <3
I used this from Amazon and it finally worked. I spent hours of frustration trying to troubleshoot.
It was $32.
I attempted to use an existing docking station and had all kinds of issues.
Another thing was I saw no speakers show up in the MA1 with this unit at first, then I either did a laptop reboot or perhaps it was only a MA1 reboot after the complete cable connection. Only then did my speakers all show up in the MA1 correctly. In other words you can't "hot swap" like on usb ports. You'll need to reboot after wiring up in order for the monitors to be recognized in MA1. Dont daisy chain either, come out of each port to a respective speaker. This crap is super finicky.
