Thanks. Funny is, that this theory is spread here even from a speaker manufacturer. He is saying that at frequencies where the half length of the wave is longer than the longest wall in the room the pressure is unstable and try to leak from every small hole. So that open doors is enough to loose this pressure, and that there is problem to solve it.
I also don't think that you can't hear 20Hz in small room, but maybe there is problem to keep the same level or slope at all frequencies with doors, windows,... open or close.
Acoustics is not an easy discipline...
I think, that I don't need to hear 20Hz in music. I think, that 32Hz is enough for 99% of it (except organs, lowest tone of grand piano and modern EM) So maybe KH150 could be fine, with MA1 in my small 42m² room with some room gain at 36Hz. I think, that KH120II will need a SUB. There is almost a half octave difference at 90db between KH150 and 120II. So I'm still scratching my head if 120II with SUB or 150 without
