The number 74 itself is not enough to know your amp is operating or not in it's linear zone. How loud was it? What are your speakers. The M28 do have more power.Okay so this is for the benefit of those of you who like me are pondering whether to buy a good external amp like NAD M28 to use instead of built-in amps in their Denon AVR (which are objectively good buy not as good as NAD’s).
I bought this NAD and had it for ~ 10 days or something. Initial impression has not changed: no perceptible difference in sound quality except at my peak listening levels in movies ( volume ~ 74 on Denon x6500) when NAD somehow is not harsh at all but Denon just a bit is. Why it is the case I don’t know, obviously Denon’s amps are not clipping at this volume. I had the same experience - zero perceived change in sound quality - upgrading to x6500 from x4500, while the upgrade from x3400 to x4500 brought a very substantial reduction in audible noise (x3400 must have been pretty lame).
What can explain traditional manufacturers are putting a lot of components on their PCBs, when manufacturers are generally putting a lot less components, and for a better result ?We ran all sorts of tests and with uneven loading as well. If you are using the amp as I described above and like it is described in the manual it behaves and performs perfect. The only issue I see is if you would run a subwoofer on one channel and another subwoofer on third channel for instance. But that is against what’s written in the manual and recommended by us.
I have never heard or seen anyone complain about the performance of NAD M27 or M28 for instance and they are using one 1200 watt smps power supply for powering 7 channels.
I did not say that reversing the phase was all that we did. We also added capacitance to the rails. As far as I know NAD also has additional capacitance added on the rails.
Went ahead and ordered one, since new M27 are nowhere to be found anymore. Wow, it looks really nice. One thing I noticed, when I just checked, if the amp works: Without a preamp connected I have a fairly loud hissing from the speakers. With the preamp connected it's dead silent, even with the preamp switched off. Did not notice this with any amps I had before. Could someone please check, if their unit behaves the same?
That doesn’t sound normalWent ahead and ordered one, since new M27 are nowhere to be found anymore. Wow, it looks really nice. One thing I noticed, when I just checked, if the amp works: Without a preamp connected I have a fairly loud hissing from the speakers. With the preamp connected it's dead silent, even with the preamp switched off. Did not notice this with any amps I had before. Could someone please check, if their unit behaves the same?
NAD jacked up the price in January by $1000!!!I finally found an ex-display M28 at a good price this week. However I noticed that it stays warmer than I'd expect in standby. I tested the power consumption out of curiosity and found the standby consumption to be around 36 watts. The specs indicate that it should be around 0.5W. Additionally all the status LEDs on the rear panel remain illuminated green while the unit is in standby. Can anyone tell me if this is how the unit is expected to operate?
Yeah, the price increase was a bit harsh. In the event it was too good of a deal. The high power consumption in standby was just a warning and it died after 1 day. It sounded great while it lasted.NAD jacked up the price in January by $1000!!!
I've been using my M28 for the past 16 months and today it stopped powering on. On pressing the power button the led on the front goes red with the normal accompanying "click" sound before then going back to standby with the front led returning to orange. Subsequent presses of the power button get the same normal clicking sound but the led just stays orange so it's stuck in standby mode. I'll seek out service under warranty and will report back what the problem is.So far, so good. OTOH, it has been only been 9 months.
A quick update on my previous post. I bought the Musical Fidelity 250.7. It's a great class A/B amp, but with a few issues I did not consider at the time of purchase. The performance is great, I have no complaints about how the amp drives my Monitor Audio Gold speakers.Thanks, @amirm, for the great review.
I am considering buying this power amp. My shortlist includes the Musical Fidelity 250.7 (7-channel), this Nad M28 and a custom-made amp made by 'Kustom Dek' in Tasmania, using Hypex hardware. I would use this amp in combination with my Denon AVR x6400h (it has all the pre-outs) to drive my seven speakers: Monitor Audio Gold 200 5G (front), MA Gold FX 5G (Surround), MA Gold C250 (Centre), MA CP-CT260 (Height).
Despite the minor issues compared to the previous model, it seems this amp is performing incredibly well and it's also of a decent size (not a monster that doesn't fit in any cabinet).
I would really appreciate some opinions, and if there are any things I should consider when pairing an amp to my Denon x6400h using the pre-outs.
Thank you all
A quick update on this message. I decided to trade the Musical Fidelity 250.7 for the new Marantz AMP10. I couldn't stand the noise from the transformers of the Musical Fidelity. It wasn't quiet... more like a fridge let's say! It was also too heavy for me. I am very happy with the Marantz AMP 10. It's dead quiet, almost no hiss from the speaker tweeters as well. A lot of power. Weight is decent at 20Kg.A quick update on my previous post. I bought the Musical Fidelity 250.7. It's a great class A/B amp, but with a few issues I did not consider at the time of purchase. The performance is great, I have no complaints about how the amp drives my Monitor Audio Gold speakers.
The main issue is the weight (this is the most important one, as I can't really move this amp anywhere by myself, with its 32Kg). Another annoying issue is the noise from the chassis (I guess the transformers). It's not a quiet amp. I'm not saying the noise is at fridge levels, but definitely audible. I measured by room without the amp on, and the noise was 37dbA. With the amp on, 1m distance, it was 41/42dbA. So, quite annoying. Another minor issue is the led lights on the front panel. They can't be turned off, so watching a movie with these lights on will probably be annoying (I haven't tried yet).
This is a clear return for me. Looking for a lighter and quieter Class D amp, one that can be reliable and can deliver the same power and dynamics to my speakers. Next week, I'll try the Marantz AMP10. I know it's expensive to only drive sevel speakers, but that's what I am leaning towards at the moment. I've read many bad stories about Nad amps, so it seems the Marantz is more reliable. This is just a conjecture based on online reviews and comments in forums.
Thought I'd post an update. I bought my M28 in March 2022 and the warranty card states there's 3 years of warranty. On Aug 1st I took the unit to NAD's closest authorized repair centre here in Vancouver, BC, Canada. After a month nothing got achieved. The repair centre said NAD wasn't sending them the parts they needed (i was told they needed new amplifier modules). I called NAD and that helped. A few weeks later the repair centre said the wrong parts were sent to them, so i called NAD again (NAD's head office and the repair centre have difficulty communicating with each other, it seems). The correct parts were then sent but they didn't fix whatever the problem is. That took another month. It's now early November and I'm still waiting for the repair centre to ship the unit to NAD in Ontario (NAD insists this must happen before they decide what to do next). I'll let everyone draw their own conclusions as to how i'm feeling about all this! After sales service will be a big consideration in my future purchases, that's for sure!I've been using my M28 for the past 16 months and today it stopped powering on. On pressing the power button the led on the front goes red with the normal accompanying "click" sound before then going back to standby with the front led returning to orange. Subsequent presses of the power button get the same normal clicking sound but the led just stays orange so it's stuck in standby mode. I'll seek out service under warranty and will report back what the problem is.
Wow! I used to provide NAD warranty service and the parts situation was very good, fast and NAD paid a bit more than the usual brand names do. I'm surprised to read of a major bad service situation.Thought I'd post an update. I bought my M28 in March 2022 and the warranty card states there's 3 years of warranty. On Aug 1st I took the unit to NAD's closest authorized repair centre here in Vancouver, BC, Canada. After a month nothing got achieved. The repair centre said NAD wasn't sending them the parts they needed (i was told they needed new amplifier modules). I called NAD and that helped. A few weeks later the repair centre said the wrong parts were sent to them, so i called NAD again (NAD's head office and the repair centre have difficulty communicating with each other, it seems). The correct parts were then sent but they didn't fix whatever the problem is. That took another month. It's now early November and I'm still waiting for the repair centre to ship the unit to NAD in Ontario (NAD insists this must happen before they decide what to do next). I'll let everyone draw their own conclusions as to how i'm feeling about all this! After sales service will be a big consideration in my future purchases, that's for sure!
NAD have at least been responsive with me each time i've called. I can always get someone on the phone and things do happen after calling them. However, their product failed after 15 months. I was faced with two options: send to NAD in Ontario at my own expense, or drive it to the local repair facility designated by NAD. Shipped insurance would have cost hundreds for me out of pocket so far better to get it repaired locally. Now, 3 months later, the authorized repair facility has said it can't be repaired and NAD are insisting they get it back to their head office. I'm hopeful for a positive outcome but it's taking a very long time and it's taken me hours of my own time to move things along. The frustrating part is there are M28's in stock everywhere but they have so far refused to send me a replacement unit until they can do their own inspection. I'll let everyone know once things do finally get resolved, and hopefully that happens this year!Wow! I used to provide NAD warranty service and the parts situation was very good, fast and NAD paid a bit more than the usual brand names do. I'm surprised to read of a major bad service situation.
