pogo
- Joined
- Sep 4, 2020
- Messages
- 2,750
- Likes
- 1,118
You can't say that for sure, but my M33 does.Are you sure DL on C658 runs at 192khz?
Learning. Thanks. BluOs also converts DSD from library.NAD DSD USB MDC
PEQ: Link
I am a new member, although I have referenced this website many times over the years. Thanks for the excellent reviews and discussions. I own a NAD C-368 so naturally I was concerned with the poor performance mentioned in this review. When I initially got the NAD, I did notice jitter. However, with subsequent BlueOS updates, the jitter started to subside significantly. Also, I have noticed that the 368 performs much better when warm. To provide a new update to this review, I have used Multitone Analyzer to check the performance of my own preamp. It is not as detailed as the original review, but it does show that another testing is warranted. It is still far from the best DACs, but at least it has acceptable performance now. Here is what my testing showed at 16 bit jitter. Please note this testing was done with DIRAC and Analog Bypass off.This is a review and detailed measurements of the NAD C658 streamer and DAC. It also acts as a preamplifier with Phono and line in. A cool feature is inclusion of Dirac Room EQ and balanced out and you get a killer feature set. For that, you need to pay though to the tune of US $1,650. The owner purchased a factory refurbished which I see going for US $1,300.
The overall design looks quite nice with a larger and informative display:
Here is the back panel:
The only feature missing that should be there is the unit acting as a USB DAC. It has a USB connector but that is it acting as a host, playing content from external storage.
Since there is no USB input, I started my testing with Coax S/PDIF. To my surprise, the frequency counter on Audio Precision was jumping all over the place as was the waveform. This indicate lack of lock on the incoming clock which could either be a design flaw or something broken in this unit.
I then switched to Toslink optical with the same result. Wanting to make sure my analyzer had not failed, I powered another DAC and it worked perfectly there.
Without these inputs working, the only digital path I had was streaming using Roon which worked fine. Roon complains that it is not certified but worked anyway.
Streaming DAC Audio Measurements
Here is our usual dashboard:
Even though performance bests the specification at 0.005% distortion, this is well below acceptable in a high priced device like this:
The only other test I can run this way is jitter:
That spray of spikes should not be there. Fortunately it is at -130 dB so not an audible concern.
Shame to see quality control or design issues in a brand like NAD. Even if the digital inputs were not broken, the performance of the DAC fails to even match a half decent $9 phone dongle. So despite great feature set, NAD needs to go back to the drawing board and clean up its implementation.
Needless to say I can't recommend the NAD C658.
The panthers are threatening "social distancing" if I don't give them a raise. Can't let that happen as I will be out of business. So please donate as much you can using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Measurement | Right Channel (JTest 16) | Left Channel (JTest 16) |
| Fundamental Level | 1.3 dBFS @ 11,025 Hz | 2.0 dBFS @ 11,025 Hz |
| Overall Level (RMS) | -3 dB | -2.8 dB |
| Total Noise | -61.9 dB - -65.5 dBA | -62.4 dB - -66 dBA |
| SNR | 63.2 dB | 64.4 dB |
| SFDR | 84.1 dB @ 99.7 Hz | 82.9 dB @ 20.1 Hz |
| Effective Number of Bits (ENOB) | 10.6 bits | 10.8 bits |
| Delay | 0 ms | 0 ms |
| Drift | 8.6 ppm | 6.3 ppm |
| Jitter (Peak) | 2073.1 ps @ 99.6 Hz | 2960.1 ps @ 29.6 Hz |
| Jitter (RMS) | 164.3 ps | 145.2 ps |
How so?When I initially got the NAD, I did notice jitter.
The preamp began making ticking noises over the audio for up to 10 minutes after being turned on. However, the ticking eventually subsided once the amp was warmed up. I initially assumed that this was related to jitter. This morning, I conducted additional measurements using the Multitone Analyzer.How so?
Since I posted new results today (see attached graphic). I will provide the explanation for that test result.What does a measurement of a C368 say about the C658?
Reading about the poor quality of the Nad 658 has demoralized me a lot.
