Digital1955
- Joined
- Feb 26, 2022
- Messages
- 61
- Likes
- 49
Classic MC response.2K to 10K sags…could that be the system (cart or phono stage)?
But the Rega Exact MM has same, with pink noise.Classic MC response.
That will depend heavily on your C & R loading...But the Rega Exact MM has same, with pink noise.
Hmmmthe CBS PN looks suspect... the HFN PN and CBS sweeep both look good through the midrange - but the sub 1kHz difference is a concern - the HFN 200Hz boost is I think a flaw in the HFN pink noise track - abd I am not sure who is off in the high end - is the HFN PN too excessive over 12KHz, or is the CBS sweep too restrained? and how can we tell! - I don't trust that CBS PN response... it looks like it has multiple issues.
As was mentioned, running the record at a different speed should expose defects in the pressing. I had been experimenting with that prior, but I have to deal with using a phono preamp that applies RIAA. Now I have swept my phono preamp directly with a test signal (from a signal generator) and created an exact filter curve to remove the RIAA (both in correcting the wav file and/or correcting the graphs), but I haven't gone back to running at difference speeds since then.Hmmmthe CBS PN looks suspect... the HFN PN and CBS sweeep both look good through the midrange - but the sub 1kHz difference is a concern - the HFN 200Hz boost is I think a flaw in the HFN pink noise track - abd I am not sure who is off in the high end - is the HFN PN too excessive over 12KHz, or is the CBS sweep too restrained? and how can we tell! - I don't trust that CBS PN response... it looks like it has multiple issues.
https://www.audiosciencereview.com/forum/index.php?threads/mm-vs-mi-vs-mc.18636/post-1123067
Start reading around here https://www.diyaudio.com/community/threads/cartridge-dynamic-behaviour.320026/post-5713672MM vs MI vs MC
My question, I suppose, is; “I see all sorts of flowery words about cartridges, but how do I choose one?” One of the most important things is making sure the cart is compatible with your tone arm. All the other things you mention won't matter much if your tone arm mass is not compatible with...www.audiosciencereview.com
I think the primary issue is the test signal type.
Geek away !! (audiophile gazing at dual oscilloscopes - who needs music, I can see it's perfec!)As was mentioned, running the record at a different speed should expose defects in the pressing. I had been experimenting with that prior, but I have to deal with using a phono preamp that applies RIAA. Now I have swept my phono preamp directly with a test signal (from a signal generator) and created an exact filter curve to remove the RIAA (both in correcting the wav file and/or correcting the graphs), but I haven't gone back to running at difference speeds since then.
I suppose we are all trying to figure out a good standard (?) way to measure the actual frequency response of a cartridge + stylus. Running the record at different speeds does provide the option of deriving a correction curve we could all apply to a record like the CBS STR 100 sweep. Certainly that ripple at ~5Khz is showing up in all our plots, so there is some consistency in that pressing.
I had another idea that I played around with but not in a formal enough way to post plots yet. I took a CD and an album that I was fairly certain were made from the same master. Obviously I can't be 100% certain. I took a 5 minute track and averaged the frequency response from the CD version, using every sample and an FFT size that yields better than 1Hz of resolution. I then did a vinyl rip and analyzed the vinyl rip in the same manner. Then I made a new plot from the delta of the two plots. Although this puts a lot of other variables into the equation, my theory was the long averaging would help better derive the response difference. I tried this with a MoFi 33 RPM pressing and the corresponding CD version they released. It did yield something that resembled my plots with test records. Maybe this is pointless. Maybe there would be some value in using this method just to add another data point to deriving a correction curve back to something like the STR 100, something it seems most of us have in our hands.
Or we could...just listen to some music. I don't know.
The mythology around the mass of coils, being a justification for LO, really is only true with the very best ultra low mass cantilever... boron or beryllium tubes... 90% + of the moving mass in a cartridge is always going to be the cantilever... a couple of % will be the needl, and the magnets or coils will acount for only a single digit % .... the lowest measured effective mass cartridges were Technics MM's.... which sort of puts the lie to the LO MC excuse!MM vs MI vs MC
Hmmm not sure we are talking about the same thing?Have you got any evidence of these ultra-low-mass-cantilever carts having a FR that doesn’t vary (much) with signal complexity?
