Tagging
@MZKM , but this is also for general discussion.
As noted in the other Kali thread, I want to advocate for calculating a score that includes the listening window
in addition to the on-axis preference ranking. I know you've tested such for the Kali and some other models. I don't mean to clutter the data too much, but I'm concerned about future readers simply looking at the preference chart and trying to determine which speaker is better from a simple numerical value.
While the preference score is a super useful tool, but it does clearly disadvantage some speakers, as shown with the Kali In-8. This will continue to happen for almost every coaxial, but also for any speaker designed to be smoother off-axis such as some designs by Andrew Jones and many speakers meant for domestic listening. In fact, I'd say roughly half of the speakers I've measured are smoother some amount between 10-30 degrees off-axis.
An additional column with preference ratings based on LW can help provide important context for a speaker's rating using the standard formula. Alternatively, if we don't want to mess with the score too much and just want to highlight the improvement from using the listening window, we can just include a "Listening Window Bonus" score or something to highlight how much of a difference there is between the on-axis reference off-axis.
Some food for thought:
- It's worth considering the context of the Olive paper: the goal was not to find which speakers sound the best, as we are doing here on ASR. Rather, it was to correlate measurements with preference. It's a subtle but important distinction; Olive did not make it a priority to optimize a particular speaker's performance, he makes no consideration of how people would actually listen to and position the speakers, nor what the intended listening axis is. His concern was only how captured data could be correlated with preferences. This is understandable, given his goal was to provide a better preference metric than the popular Consumer Reports one (at the time). On-axis was presumably chosen as the direct sound axis because it is easier to set up a turntable for a variety of speakers this way than finding the optimal reference axis for each speaker.
- More specifically, the preference formula paper used the same listening setup as the "part 1" test, in which Olive states:
"All tests were performed with a single listener in the room situated in the same seating location, who controlled the switching of the loudspeakers. The listener sat 3 m. away from the loudspeaker, on-axis to the loudspeakers. All loudspeakers were positioned so that the design axis or tweeter was approximately positioned in height to the listeners’ ears. "
So think about it; it's actually pretty obvious that on-axis would correlate with preference better than the listening window, because it is a far more accurate representation of the direct sound the listeners heard! At 3 meters, allowing for about a foot of horizontal movement, you'd never be more than about 3 or 4 degrees off-axis. Off-axis listening wasn't even an option for the tested speakers.
In other words, all the preference rating really tells us is that the first sound to hit our ears correlates more strongly with the preference than a 30-degree horizontal and 10-degree vertical average. This is not surprising.
- However, we know from the Devantier study (which determined the listening window from studying positioning in 15 homes), that the average setup is 10 degrees off-axis. Moreover, more people listen off-axis than on-axis, and nearly as many people listen at 20 degrees off-axis as do at 0 degrees. So any way you cut it, the on-axis measurement simply isn't representative of most real-world use.
- Of course, the Listening Window isn't perfect. It's a wide window and will be smoother than the on-axis simply by virtue of being an average of 9 measurements. However, again, our goals are different than Olive's. He wanted to develop a preference formula. We're trying to figure out which speakers are the best. The Listening window is arguably a fairer representation for a diverse body of speakers positioning a variety of ways, many of which are designed to be listened to off-axis.
You could argue that what we really should be doing is using the best listening axis, but that's a lot of work still leaves coaxials at a bit of a disadvantage. I think simply seeing the difference between the listening window and on-axis based preference scores should be enough to tell you whether you should be listening off-axis.
- Dr. Toole himself makes a similar argument for using the listening window instead of on-axis when it comes to calculating the Directivity Indexes. In his book, when discussing how engineers shifted from calculating the directivity index from the on-axis to the listening window, he says:
"It was decided to depart from this convention because it is often found that, because of symmetry in the layout of transducers on baffles, the on-axis frequency response contains acoustical interference artifacts, due to diffraction, that do not appear in any other measurement. It seems fundamentally wrong to burden the directivity index with irregularities that can have no consequential effects in real listening circumstances."
In that vein, I'd also argue it seems fundamentally wrong to burden the preference score with irregularities that have no consequential effects in real listening circumstances.
So I propose showing both a score with a listening window and one with the on-axis. Otherwise, speakers designed for good on-axis sound will always sound better, even if that curve isn't actually representative of the first sound to hit our ears.
If we wanted to get real funky, we could also calculate a score with the smoothest NBD axis and include that in reviews for positioning advice, but that's probably asking too much.
