Does this one pop like the e30 and other topping / smsl at low price points (when used as pre-amp)? It's driving my wife up the wall when putting on YouTube videos for my 3 year old. Every bloody video it pops after the video ends and when the next one starts....
Maybe - August 11th...2020-11-08 which I'm assuming means November 8th.
But all other dates in that table use YYYY-MM-DD format.Maybe - August 11th...
Its already under 200Shouldn't be long for this level performance under $200.
Is there a reason why this D30 review hasn't been added to the Master table of reviews yet?
The table says: Latest review date: 2020-11-08 which I'm assuming means November 8th.
You need to turn on wasapi output in your Player (sometimes called exclusive mode) or set Windows Audio settings to your desired sample rate. Although upsampling is useless and will hurt your audio quality.Hi everyone, it's my first message here. I was looking for a DAC last month, discovered this forum and was pleased by this review. So I bought a Loxjie D30 from hifi-express and got it yesterday after three weeks.
Sound is really enjoying even with Bluetooth. I may be dumb, but I can't go beyond 44100 Hz. I'm using foobar2000 or Jriver Media Center 25 and I feed them with 48000, 96000 and DSD64 files: each time the DAC stuck at 44100 on the OLED display (confirmed by the XMOS USB DAC Driver Control Panel, coming from loxjie website). I have no known resampling feature enabled somewhere.
Does someone have an idea? Did I miss something?
You answered in the meantime: yes it was that sample !You need to turn in wasapi output or Set Windows Audio settings to your desired sample rate. Although upsampling is useless and will hurt your audio quality.
First, you need to find the source of the noise. Does the D30 noise disappear when I remove the Power line net adapters?I've been reading/lurking quite a bit on these forums, but just created an account. As often is the case with reviews as well, people keep quiet until there is something to complain about. I think (or hope) I would have also created an account to give praise, but regrettably my first post is about an issue.
After the positive review of the Loxjie D30 and concluding I did want to try an external DAC/AMP with my Fidelio X2, I decided to jump on the 11.11 discount and bought one. My PCs onboard sound (Realtek ALC1150) performs well, but I still wondered whether I would hear improvements in 'fullness' or less distortion on peaks.
Now I don't know whether it's a characteristic or a faulty unit, but after turning the D30 on I was immediately disappointed. From the get go I can hear a clear distortion. This distortion:
- Does not sound like a pure tone/sine, but rather like something pulse modulated at an audible frequency.
- Does occur without any input connected, only power and the headphone cables are attached.
- Does not vary with volume setting, it stays at a constant level regardless.
- Seems to reduce somewhat when touching the unit.
- Also sounds softer when connected to an outlet without ground pins.
Further observation: I'm using powerline net adapters (Devolo magic 2 next). The distortion sound softer when plugging in the D30 in a socket further away from a powerline adapter.
My conclusion: It seems to be bad at filtering mains noise. My PC's sound is (audibly) silent, at the same time the DAC/AMP produces loud and clear noise (this is no soft background hiss by any means).
My question: Other than getting rid of the powerline adapters, can I do something to get rid of this audible distortion? / Do you think it might be a faulty unit and is an RMA worth a try?
Was planning on testing that. Can't during the day, since internet is a first world necessity while working from homeFirst, you need to find the source of the noise. Does the D30 noise disappear when I remove the Power line net adapters?
This sounds to me like a ground loop. It’s common and has nothing to do with the unit. There are lots of threads here that deal with it.I've been reading/lurking quite a bit on these forums, but just created an account. As often is the case with reviews as well, people keep quiet until there is something to complain about. I think (or hope) I would have also created an account to give praise, but regrettably my first post is about an issue.
