@audio2design, while your observation is basically valid, you have to put it into perspective of things.
Yes it is true that a cable can have a different linear transfer function depending on direction, just as any other 4-pole network.
But, for all intents and purposes the effect is irrelevant as
(a) the "damage" is linear (amedable) and
(b) it is so incredibly small that it doesn't matter.
I can measure such things down to -160dB below signal and there is nothing to be found with cables (teaser here: https://www.audiosciencereview.com/...dible-with-music-signals-some-examples.20886/)
One would be very hard pressed to build a cable in the normal way cables are built that actually showed any directionality to amounts that would result in more than, say -120dB of frequency response variation (mag and phase) in the audio range, and that maybe also would sport a non-linear behavior, again in -120dB realms.
So, within context, the statement of Douglas Self is 100% correct and does not violate anything.
You are supporting the same fallacy that many Golden Ears are fooled with by manufacturers: Just find any phenomenon that is is real and correct and verifyablem then construct a case around it.... but is complete irrelevant in applied theory as well as in practise as the order of magnitude of the effect is way way below any sensible thresholds of hearing, we're talking about a distance of 60dB++ to those thresholds.
